Results 1 to 5 of 5
Thread: vibration between 80km/h - 85km/h
    pr0n's Avatar
    pr0n is offline It's A Me ' MARIO '
    03 VY II S V6
    Dec 2006
    Gladstone
    Default vibration between 80km/h - 85km/h
    my vp has a vibration between 80 - 85 km/h but its only when when 4th gear engages it starts, the gear box is fine fluid is not burnt, its a nice redish, fluid level is fine. after you pass that speed the vibration stops, so normally when it starts i bump it back to the white D then when the revs hit 2000 i put it in the blue D and the revs drop somewhere between 1600 - 1800 rpm at 100km/h and cruises along nicely anyone have any ideas?
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    I've heard that the vibration is something to do with the torque converter, can't remember what exactly though. Look it up on google.
    I know a few people who own cars that do this, but it's never really resulted in failure.
    pr0n's Avatar
    03 VY II S V6
    Dec 2006
    Gladstone
    im not really worried about it atm because i got a car new car to do up, but i was just wondering if anyone else has had the problem, im thinking the car has a really really good gearbox because it doesn't matter how hard you up it , it always changes verry smoothly because you cant feel it change gears but if you listen you just hear the engine noise drop, its a hell of a lot smoother than my mates stock vu ute with only 100,000km on it and mine has at least 280,000km on it, not actually sure as its a different dash in because when i pulled it out it has VN V6 written on top
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    Quote Originally Posted by pr0n View Post
    Had the same problem. Also pointed to the gearbox as the problem but ended up being a blocked injector which meant I was running on 5 cylinders. Cleaned the injector out and the vibrations stoped. I think when you loose a cylinder you put the engine out of balance? Correct me if Im wrong
    camstatic's Avatar
    VP S1 V6 Executive
    May 2006
    Regional SA
    It can feel out of balance, yep. Although technically, the engine itself is still balanced.
  1. Engine revs changing up/down when coasting over 80km/h
    By vsuterus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 09:18 PM
  2. Vibration ?? V6-96 VS
    By zapper in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2010, 07:46 AM
  3. Odd vibration around 80km/h
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2009, 07:01 PM
  4. Staffy + VY @ 80KM/PH = FRONT END GONE. VZ REPLACEMENT
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-06-2008, 02:04 PM
  5. Nosie from Engine ot Gearbox while travelling 80km+
    By bsbozzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2006, 02:20 PM
