My drivers seat broke away from the runners, so I took it out and stripped it, welded it up and put it back together, once I have it back in the car the hieght adjuster keeps going to the top once I get out and take the weight off it.
If I set it to about half way if I go over a bump it goes to the bottom again. All the nuts are tight and in the right places, only things I had spare were 2 little rubber things.Did not see where they come from.I stripped it outside at night as the wife needed to car in the morning, and I could not get into the garage due to a dead 4x4 in the way
To fix this originally I just knocked the pin out that holds the spring which is loaded up and wrapped around the shaft in place... But I'm quite tall and wanted the seat on the floor anyway, you can weld the teeth on the height adjuster too however...
Yes I thought of that.It been a bit suspect for a while,Now its real bad. once I played with it
look for a place were it rubs. It would have to have friction to stop it moving.
You can get rs seats complete for next to nothing. Just ask the wreakers
Get an old seat base from thew wreckers, stuff messing wif them.Seats are everywhere & cheap as.Shuv on a anuva base.Dun this many times 4 my 18yr old idiot teenage son here.He keeps coming home from the wreckers wif diffrent types of seats 4 his VN.I have so many old seats here now i'm thinking of making a bus.Damm kids..ffs..!!The other day he scorred him sum VT SS seats.A bit dirty but ya can't winge 4 $80 for the fronts & rears.The drivers seat base was broken, wat is it wif the bloke at GMH welding seats ffs..??I just happened to have several spares here so i did sum surgery.
Took me 2 washes wif sugar soap & a scrubbing brush to clean them.They look llike newies now.He's happy..
Tony 308vkcalais:
my house has a double garage and one drive width to it so it can be a pain, the 4x4 is a runner again so I have the garage now
