ey guys, my heater has pritty much carkd it. The heater doesnt work/blow air out of vents, when switched to 3-4 fan speed the passenger can feel air at there feet and you can hear it. My front demister also has stopped working.
Any help appreciated![]()
plug has come off the back of the control of the vacume hose from the engine is stuffed.
The control unit has a vacuum plug with the vac line in it - probably come loose.
and 3 Dangerous non ABS VN's
sweet will check it, cheers for that. hopefully nothing major.. also where is the control unit located?
