Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: Seems transmission coolers really are beneficial...
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Smile Seems transmission coolers really are beneficial...
    I'm in the process of replacing my 500,000+++km VN V6 engine with a rebuilt VR V6. While preparing to remove the original motor, I dumped the transmission fluid, having driven it approximately 15,000km since the last change. Usually after 20,000km (my regular auto service interval) the fluid is a murky brown colour. Last time I did a fluid change (15000km ago) I installed two additional transmission coolers, making three in total.
    I will post up photos shortly of the fluid in the bottom of the pan. It looks like it was changed only yesterday. I am extremely pleased to find this and will look at increasing the service interval for my automatic transmission to possibly 30-40,000km.
    Sam
    photos:
    15,000km fluid:
    ATF cooling path:
    passes through radiator in-tank cooler first
    then out the side and through this Hilux diesel cooler
    then around the front and through this random other cooler I found
    then back to the transmission
    WTB: mulberry VN interior parts
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    yep, auto transissions live or die by the running temp of the fluid. get it too hot and the fluid can create a varnish on the inside of the trans, when this happens it looses it's ability to transfer heat (i.e. it looses it's cooling properties). excessive heat will also harden seals and other plastic/rubber parts.
    Body by Holden, Soul by Brock
    the Legend will live forever
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I was stunned. I have never seen fluid this clean come out of a transmission in my life. It made me so happy
    Ado's Avatar
    Ado
    Ado is offline Are we there yet?
    vsII statesman L67
    Apr 2008
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    i ran one on my fairlane and i have to say it dose stabilize the fluid temp far better with a trans cooler and as for shift performance it helps and long lasting trans fluid for sure unless you tow huge weight often so yeh a trans cooler is the way to go
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I've had a couple of people comment that three coolers are a bit .. well.. overkill. Here's how it came about:
    I was only going to add that one at the front but I ran out of hose and needed the car back on the road immediately. I hunted around the shed and found two short bits of hose but nothing I could use as a joiner. Then I had an idea that another cooler could do the job as a joiner.. I found one I had lying around and figured out I could mount it on that convenient diagonal rail in front of the passenger wheel
    Was never intended to be 3 of them, but it seems to work quite well!
    vp 5L
    Jul 2008
    goldcoast
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I doubt it. The ATF leaves the gearbox a hell of a lot hotter than the coolant at that end (cool end) of the radiator. That fluid heat transfer that occurs in there is far more efficient than the air cooling that occurs in the other two.
    edit: just noticed, this is my 2,345th post
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    Jun 2008
    golden beach
    i agree best to run it via the rad after all in a normal situation the rad isn't to bad i wouldn't run the a/t to cold you may cause damage
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I don't think it's running too cold. Not much chance of that really with the amount of heat soak from the engine
    Morton's Avatar
    Fairstar the Funship
    May 2006
    You should rotate your diagonal cooler to actually face oncoming air
    The 1972 HQ Kingswood
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Too much like hard work. It still radiates, that's good enough for me
  15. #15
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    i put one one me vs the other day..however im not sure if i hooked it up right as i ran the top hose from the radiator to the cooler then cooler back to the trans..? is this teh correct way? as i want it to go from trans to radiator then radiator to cooler then back to trans but dunno if if i hooked it up right:P
    cheers
  16. #16
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I THINK you actually need to put it in the bottom hose. The top one is the feed line FROM the auto. At least, I really hope it is otherwise mine are in wrong
    **someone able to verify this?**
  17. #17
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
  18. #18
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
  19. #19
    pando666 is offline milk comes in 2 litres
    vs exec
    Jul 2008
    sydney
    So does anyone know for SURE which hose to put the cooler in bottom as you(savage)has done or top as Jas did?.
  20. #20
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by pando666 View Post
    Id say bottom which is the return line. The radiator cools the fluid to engine temp which is still quite hot. You dont want to cool the fluid through a cooler then heat it up again before returning to the trans.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
  21. #21
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    lmao yeah man it's the bottom line
    If you want to make sure, try cranking the motor (not starting) with both lines removed.. fluid should piss out the top one. Mine blew off on first startup of new motor. LOL
  22. #22
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    It works on the same principal as the radiator, funny that . Heat rises, so the bottom is the outlet.
    Unless someone replaced the hoses and mixed them up it should be right lol.
    My (ex)Ride
  23. #23
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by azzfox View Post
    Dude.... that makes so much sense. How the crap did I not think of that?
  24. #24
    VP Executive R-spec
    Jan 2005
    Azzfox is half German, he can't help it, it's in ze blood to figure stuff out
  25. #25
    VL 5L inj
    Sep 2007
    Woodburn, NSW
    The reason a lot of people bypass the radiator is the radiators have a tendency (esp fords lol) of cracking and sending water through your gearbox. when it gets water in it, all the glue on the clutch linings fail and they all end up floating round in the gearbox and you end up with a dead auto. this exact problem happened to my parents falcon a week ago. according to the auto mechanic the BA falcons are the worst culprit of doing it. im buggered if im gonna risk that, im air cooled only about A4 sheet size cooler.
  1. [VIC] WTD- transmission coolers & VN exhaust 3"
    By jenkos_vl in forum Parts And Other Items For Sale
    Last Post: 21-03-2009, 05:49 PM
  2. Transmission Coolers In VN-VS Holdens
    By shonky12 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2008, 08:13 PM
  3. Transmission Coolers - what models had them?
    By Old Colts in Oz in forum General
    Last Post: 26-02-2008, 12:52 PM
  4. Replies: 11
    Last Post: 17-10-2007, 07:52 PM
  5. Transmission coolers needed?
    By VXIIwagdf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2006, 05:38 PM
