Results 1 to 6 of 6
Thread: help fitted a swoosh tacho no lights
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    Question help fitted a swoosh tacho no lights
    i fitted my swoosh tacho today and cant figure out how to set up the lights for night view there's a cord from it with 4 gray wires and a yellow i understand where and how i would fit it to the lights on switch but cant figure out how to with these wires has anyone came across this before and if so i would love the help
    other than that it works fine just cant see it at night !!
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    Jun 2008
    golden beach
    surely someone knows and can help
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    It must have come with a manual to give you a clue. I would imagine 1 wire is earth and another will run to the globe. Can you pull the globe out at the back and continuity test the wires to work it out, that would be the easiest.
    Reaper
    Jun 2008
    golden beach
    no manual it was second hand i might try again today
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    I just went and had a look at a swoosh tacho i had lying around mine has 5 wires coming from it:
    These 3 wires are connected to the rear PCB board:
    red = 12v
    blk = groun
    green - tacho pulse
    These 2 which i assume are the illumination and seem to be connected to the outer edge of the tacho
    red = illumination wire (tap into ciggi light power)
    blk = ground
    Jun 2008
    golden beach
    problem solved thanks guys
  1. Anyone fitted a CRS kit to a VY 3.8Lt
    By cmelb in forum V6 Development And Modification
    Last Post: 24-11-2008, 09:03 PM
  2. Replies: 21
    Last Post: 23-06-2008, 08:19 AM
  3. VN Tacho-Less Dash To Tacho
    By Evman in forum General Discussion
    Last Post: 01-03-2008, 08:32 PM
  4. VN dash lights + tacho issue
    By timmy_tam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-07-2006, 02:48 PM
  5. VN tacho + lights - ECU OR BCM?
    By timmy_tam in forum Electrical Wiring / Questions
    Last Post: 24-07-2006, 11:51 AM
Tags for this Thread
