Results 1 to 10 of 10
Thread: VN V6 Trans Slipping on up and down shifts
    goldvnaero's Avatar
    goldvnaero is offline HOLDENS RULE
    Vn v6 Wagon
    Apr 2005
    Noarlunga Downs
    Question VN V6 Trans Slipping on up and down shifts
    hey everyone,i have a slight problem with my trans on my vn v6 auto trans.Its fine when its cold but when it warms up the up changes are a little sloppy and slips a little,and when kicking down a gear it also feels the same.like its slipping,but as i said its fine when its cold..does anyone have any ideas on wat it could be??i live at noarlunga so if anyone knows a good decent reliable trans specialist up this way i would be glad to let them have a look at it.thanks ppls.
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    stupid question but i will ask it anyways what are your fluid levels like and how long since the box has had fresh fluid in it ?
    and if you are going to take it to a shop get a stage 2 shift kit and get them to fit it then the box will be good for years to come
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    goldvnaero's Avatar
    Vn v6 Wagon
    Apr 2005
    Noarlunga Downs
    fluid levels are fine,and im not sure when it had the fluid changed as i have only just bought the car 3 weeks ago.hoping it just needs a service and filter.will def get the shift kit at some stage tho.
    Jun 2008
    golden beach
    if ya have the cash its better to get it done with the service less fluid wasted that way
    goldvnaero's Avatar
    Vn v6 Wagon
    Apr 2005
    Noarlunga Downs
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    I wouldn't go putting a shift kit until you get it fixed first. The gearboxes don't slip, virtually impossible. Could be a buggered torque converter. Or low on fluid. Get it serviced and get the dudes to check your box out for anything else.
    It's usually the service pistons that let go before the actual clutch bands go. If clutch bands go, might as well be up for a reco.
    Yours Kindly,
    Jim
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Quote Originally Posted by VTSSDUDE View Post
    Nah they do.... a lot...
    Id say its up for a rebuild if its doing it a lot like that.... it might be shitty fluid but still....
    aZk.
    goldvnaero's Avatar
    Vn v6 Wagon
    Apr 2005
    Noarlunga Downs
    its going in tomorrow morning for a service so that might sort it out,if not its prob rebuild time and a shifty.will let ya know how it goes
    goldvnaero's Avatar
    Vn v6 Wagon
    Apr 2005
    Noarlunga Downs
    got it serviced and it seems alot better now.not slipping at all when changing up or down now,def getting the shifty done soon tho
    Jun 2008
    golden beach
    good do it and dont look back
  1. slipping trans componment
    By VL Berlina 5speed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2009, 06:10 AM
  2. VS Calais V6 trans slipping when under throttle and kicks back
    By goldvnaero in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2008, 10:37 AM
  3. trans slipping
    By controlled chaos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2008, 04:18 PM
  4. Auto Trans Slipping? (VS)
    By nado69 in forum General
    Last Post: 26-09-2007, 12:41 PM
  5. vr calais check light on trans slipping under revs
    By Nudude in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2007, 05:39 PM
