Results 1 to 6 of 6
Thread: box n engine seperation
    Vn aero mock
    Apr 2009
    Unhappy box n engine seperation
    just bit stumped taken all the bolts out wires and hoses but the box wont budge do i need to seperate the flexplate and torque converter?
    Vn aero mock
    Apr 2009
    VT spac super6
    Nov 2008
    Riverton sa
    first off double check all the bolts i always forget one lol
    and the best way to do it is to unbolt the convertor from the flexplate, then the box only needs to go back an inch and will drop straight down
    Vn aero mock
    Apr 2009
    Vn aero mock
    Apr 2009
    do i need to mark the flexplate or the torque converter or anything like that
    Morton's Avatar
    Fairstar the Funship
    May 2006
    You need to undo THREE bolts that join the FLEX PLATE to the TORQUE CONVERTER. They will face the engine. Undo them with a large breaker bar, and use a breaker bar on the crank pulley bolt against the chasis rail to stop the motor turning. Alternatively, jab a cold chisel in against the side of the block through the flex plate to stop it turning.
    Once the torque converter and the flex plate are separated, you can slide the trans back, and lower it down.
    The 1972 HQ Kingswood
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  3. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine stalls and engine light comes on.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:01 PM
