seems to be coming from the back of the car, can't tell exactly where... its been like that for a while but in the past week has got alot stronger, could this be the case if my car is running rough/rich or w/ever? i only getting 300k's to a tank fwy driving to work and back, not local driving
check all the breather hoses in the driverside rear wheel arch behind the removable metal panel they are probably all perished and broken off
^^ agree - all VN's are getting to the age where the petrol hoses at the rear by the tank are perrished.
First you will notice when you fill the car up to the top. Then slowly it will happen all the time if the return hoses split. Pumps petrol onto the top of the tank. Real fire hazard.....
and 3 Dangerous non ABS VN's
i dont see the problem with the fuel smell, as fuel smells so nice *bakes*
cheers guys, well my previous car i could overfill to the very top, now it overflows onto the ground(it doesn't come out the top of the neck of tank, somewhere inbetween?), im not sure why? not ssure if that has anything to do with petrol smell
got a gm book on the fuel tank set up if your interested in a scan, just buzz me an message
Breather hoses, I had the exact same problem.
Don't fill up the tank past the first click and you will be right.
