Results 1 to 23 of 23
Thread: Very bad fuel economy VN V8
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Default Very bad fuel economy VN V8
    Ey guys just put $40 of 98 octane premium fuel in, which was 31 litres or something like that. So far ive only done 80k's since filling up and im already on red line. I also just serviced the car oil change/filters/leads and sparkplugs, I did the leads and sparkplugs due to it was jerking/missing while driving that problem went away but now seems to be haunting me again.
    Any ideas on what this could be? I was thinking maybe a leaking injector.. car is virtually stock as a rock CAI and exhaust system.
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    VN
    Jan 2009
    Newcastle, NSW
    The gauge is accurate yes? :P
    If you can, get the car up on ramps and run it for a bit. Check all the steel fuel lines from the fuel tank to the engine bay for pinhole leaks. Check all rubbers.
    Check the fuel rail for leaks.
    If all is a-ok, its it's likely leaking injector, or a dodgy sensor (oxygen sensor for example) that is causing it to run really rich.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    oxygen sensor and coolant sensors are a good start and a new thermostat of the correct temp and check the base timing
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Hmm Im more pointing towards the coolant sensors, as going by the gauge its over cooling which results in more fuel consumption yeh?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if its not warming up or not warming up fast enough will cost a lot of fuel.thermostat and ecu temp sensor will be a good start
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by Noy View Post
    31 Lts will get you 200k's or so. The missfire could be dizzy cap/rotor button - as you have changed leads and plugs. A leaky injector probably wont give a missfire. A blocked injector may do so - but would probably have a miss at idle.
    Id start with replacing the O2 sensor and temp sensor as Delcowiz said ^^^ first and check the contacts on the rotor button/dizzy cap.
    and 3 Dangerous non ABS VN's
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Cheers guys, yeah going to go to holden tommorow and buy an O2 sensor and temp sensor.. holden stock them still yeah?
    VP Executive R-spec
    Jan 2005
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    if the coil is original it may be time for repalcement as well. also check the static timing on the dizzy. may not be your problem but can't hurt to check anyways
    Body by Holden, Soul by Brock
    the Legend will live forever
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Just on a side note, will replacing the coil actually make much of a difference if im not having misfiring problems, i.e original coil but runs fine.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Hmmm..... I'd be happy if I got that far in the VP.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VP Executive R-spec
    Jan 2005
    HSV472's Avatar
    HSV472 is offline i just got one
    hsv vr clubsport
    Jun 2008
    s.e melb
  15. #15
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you will feel it lock up at 80+ kmh in 4th feels like the box has 5th gear
  16. #16
    HSV472's Avatar
    hsv vr clubsport
    Jun 2008
    s.e melb
  17. #17
    VP Executive R-spec
    Jan 2005
  18. #18
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Quote Originally Posted by greenfoam View Post
    I rekcon I win the diagnosis on this one
    Looks like you did, thanks for your help all
    Bloody VN's.. its times like these I wish I still had my army tank aka vt
  19. #19
    Reaper's Avatar
    Aug 2004
    I'm still in awe that somebody actually gets 80 km from a tank on a Holden 5 Litre.
    Reaper
    Reapers Black VP SS
  20. #20
    VT V8 Calais
    Mar 2007
  21. #21
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by 50LTRv8 View Post
    you serious?, I get about 500 out of mine thats a stocko though
    I have done 1500km in this car and would be the most expensive 1500km known to VP man!
    Reaper
    Reapers Black VP SS
  22. Default
    haha doesn't sound good reaper. no idea on petrol, but my car seems to use as much idling as it does driving on gas. probably needs a good tune (although it was only tuned about 5 months ago), but i just got 185kms out of 48 litres. wasn't too happy at all
    Quote Originally Posted by zai View Post
    I am not sutpid
  23. #23
    Apr 2006
    Auckland NZ
    i think reaper only knows 2 throttle positions in the VP, boot fully planted and no throttle (and only then because both feet are on the brake ) and thats only when he's not modifying something or rebuilding the engine
  1. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  2. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2010, 04:29 PM
  3. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-07-2010, 01:15 PM
  4. Bad fuel economy, strong fuel smell?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 08:43 PM
  5. Fuel economy per tank of fuel
    By HoZy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-05-2007, 06:58 PM
