Originally Posted by
Cogez
VN/VPs are always broken, and it's outrageously frustrating. So I've thought it a good idea to make a post where everyone can list every single thing that's wrong with their car, and maybe someone nice might PM you with tips...or more likely just laugh at you coz they have the same problems too.
I will start (this could be quite long)
Engine ticks - Most likely your lifters are worn, replace
Diff clunks - Excessive backlash or damaged uni joints, recalibrate or replace unis
Mudflaps scrape - ppffft, who uses mudflaps? Remove
Engine mounts worn to nothing - Replace Engine Mounts
Fuel gauge has to be bashed to work - Dry Solder joints on PCB, resolder
Fuel gauge light doesn't work - Renew globe, Renew Connection, Check Sender Unit
Left bank of dash lights don't work - Replace Rear Illumination Globes
Piece of plastic in auto trans selector that has a green clear bit that lights up what gear you're in, is snapped in half - Replace Gear Select Indicator
Piece of dashboard under steering wheel got broken in half, so is now gone - Replace Lower Steering Coloum Surround
Boot light farked - Check Globe, Check Pressure Switch, Replace as necessary
Glove box light farked - Check Globe, Check Pressure Switch, Replace as necessary
Cigarette lighters farked - Check connection to both tip and sleave, check fuse, replace parts as requried
Map lights have to be bashed to work - Check connection joints and recalibrate globe mount point
Rear reading light farked - Replace globe or lense case as required
Drivers seat slowly tilts backward, so you have to readjust it every week - Amend broken tilt adjustment pin in control wheel, there is a how to on this
Car is covered in scratches, paint chips and hail damage - Respray panels as required
Park light gone - Renew Globe
Brakes worn - Check pads for RWC friction material, ensure rotors are clean and free of wear or scoring, bleed brake system, renew components as required
Rear tyres bald - Replace tires
Licence plate light farked - Check globes and connections, repair/replace as required
A/C makes sounds like it's dying an extruciating death - Check compressor pulley bearings, connections and refrigerant gas pressure. Replace / renew as requried
Rear left power window doesn't come down - Renew primary release cable spindle pulley in winder arm, renew cable if frayed or damaged
Alarm sets itself off for no reason - Possible earth leak or oversensitive tilt/shock sensors, replace as requried
Remote central locking only locks the two front doors - Incorrect wiring or acutator fail, check wiring connections between BCM and slave acutators, replace faulty units as required
Tint peeling off the back window, after 2 months - Consult warrenty on tint, renew if required
Boot lock smashed up with a screwdriver, pretty Holden badge broken off - Renew boot lock, install new pretty badge
I reckon that might be all...and I feel much better =P
