Results 1 to 16 of 16
Thread: How to remove...??
    Fun_Bucket's Avatar
    Fun_Bucket is offline Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Default How to remove...??
    Hey guy's, my VP is going in tommorow morning to have it's engine and gearbox mounts done, now the mech said if i take the Air con pump off prior it will save me some money. I've had a look under the bonnet, but i'm not really sure what i have to remove. Theres a canister type thing on the back passenger side which say Jayair on it, i've removed this, is there anything else i have to take off. Im not really worried about re-asembly right now cause the Air dosent work anyway...Thank you any one who can help
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Quote Originally Posted by holdencommodorevp View Post
    Dont worry about the canister, he means the acutaly pump. It has a belt going to it at the bottom right of your engine near your CAS.
    The only thing is, if the canister is still filled with gas, there will be no way to remove the pump otherwise you will vent gas into the atmosphere... which is bad! Just the pump needs to come off...
    aZk.
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    why would you need to remove anything to start with?
    i thought it was as easy as unbolt the engine and lift it a little, change the mounts and re-secure.
    gearbox is basically unbolt, lower slightly and replace - that simple.
    May 2005
    .....SE Burbs
    Quote Originally Posted by davway View Post
    The right hand side is a prick to do without the air con off, the retainer bolts are hard to get too..
    Gearbox is literally easy as piss....
    aZk.
    Nov 2003
    Warrnambool
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by azkwazere View Post
    aZk.
    I looked at that and thought it had to come out, what about the belt, looked like it would be loose after i took out what i think i have to take out. ?
    Vp series 2
    Jun 2008
    ok a good idea would be to undo the bottom couple bolts on the ac compressor as they are the hards ones to get at.
    four bolts thatgo into the cmpressor from the side the 2 bottom ones are a bitch to remove.
    get a belt for a non ac commodore and leave the compressor out.
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    So once i remove the pump, the belt will no longer fit right? How did the mech in that case, expect me to remove it and then drive it to him?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Leave it for him. Wasting your time at home, as you say how ya gonna drive it with the belt off and its a big pain anywayz.
    Reaper
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    yeah it's gonna have to wait for him, it's dark and raining now, and gone on too long. Thanks for the help guy's. Oh and AZKWAZERE, too late, took the canister off, so that's what that niose was when i undid it haha, oh well, the ozone if ****ed anyway right?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    just on topic with the aircon, mines kaput, but i don't know if it's someting wrong with the compressor or just all the gas has escaped. if i'm lifting the engine out i'llneed to undo the lines from the compressor to the canister, will this release the freeon or whatever?
    it looks like a similar setup to where the brake lines join the caliper, is it just a banjo bolt arrangment?
    May 2005
    .....SE Burbs
    Quote Originally Posted by pow3rslave View Post
    yes, it will release any gas left in the unit unless you take it all out as a single system, ie, the condensor, canister and pump all still attached to each other. If i was gonna do it, i would loosen the feed line (high pressure) to the pump from the canister and slowly bleed it from there as you only have to slightly loosen the retainer bolt and break the seal, the thread will stop it flying off.
    aZk.
    Vk wags & Vl berlina
    Nov 2008
    if your gunna go to all that trouble to take the A/C off you might as well do the mounts yourself
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
  15. #15
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    only need a jack to lift the engine
  16. #16
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    yeah i'd be tempted to give it a go, but i dont know exacty what i'm doing, and i've heard from people who have done it, and knew what they were doing and they said it was still pretty hard. Plus i'd be doing it on my own, i've just moved interstate, maybe if i had a mate or two doing it with me i would have given it a go.
  1. remove a/c? VR
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2008, 11:16 PM
  2. how to remove?
    By nook in forum General
    Last Post: 09-12-2008, 05:31 PM
  3. About to remove this....??
    By nicko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2008, 11:53 PM
  4. How to remove cam
    By ascension24 in forum V6 Development And Modification
    Last Post: 13-03-2007, 11:46 AM
  5. how to remove
    By figjamidhVK8t4 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-10-2006, 07:17 PM
