Results 1 to 13 of 13
Thread: Problem, after problem, after problem.
    Jul 2008
    Default Problem, after problem, after problem.
    Ok my question is, will my manual bits off my S2 vp commonwhore fit a vs.............
    Ive reached a high level of frustration with this crappydore, you fix it, and another part breaks, classic example tonight, I had to crawl under it to fix up a leaky fluid transfer pipe of my steering rack... ( im not even sure if its fixed i cant move it till morn ) and while i was at it i figgured id fix my flappy door trim which only just broke.
    So i fixed that, and the junk compartment they have on these door cards, and then the crappy bit of plastic just behind the side mirror decided hey i dont wanna go back on because when you removed me my frail arsed shitty plastic clip decided to brake, and no the screw isnt good enuff,just to **** with you, im going to completly fall off leaveing just the screw in there and the remains of plastic stuck behind it.
    Yeah, ok im ranting.
    Long list short,
    Gearbox = no good
    Motor = no good due to sticky lifter and iradic idle.
    Clutch = no good.
    throw out bearing = no good.
    Diff = no good.
    Brakes = no good.
    Paint = no good.
    Tyres = no good.
    Interior = fair condition but not good enuff for me !
    Im fighting the very strong urge to petrol bomb this thing just so i can get the sadistic satisfaction of watching it burn for causeing me so much frustration.
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    true some nulon lifter free tune up thing in your oil that fixed my tick, then add some nulon fuel system cleaner in ur petrol mite clean ya injectors lol thats one thing fixed for ya :P
    sorry to hear bout your car man that last line of ur message made me laught too
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Sounds normal, whats the problems you have.
    Reaper
    Jul 2008
    haha no worries man, Im glad you saw the funny side
    lifter free doesnt work, the lifter is shagged.
    I just think im at the point where to me this car has to many problems to be worth fixing up again and want to move on to something better, BUT it has to be manual ! I refuse to drive another auto commy EVER !
    Jul 2008
    Quote Originally Posted by DavoVP View Post
    Oh the Q with the rant attachted was will my go bits of my vp fit mate up to a VS, specificly the manual transmision !!
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    ohhh ok a shagged lifter aye lol not asking how that happened
    lol jks man
    what next car are ya thinknig of getting?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Just to give you an indication thus far the only mechanical bit I haven't had apart in my VP is the fuel tank. Most other parts have been out on multiple occasions. Get used to it if you want something this old.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Jul 2008
    I was thinking of a VS, But only if i can score a manual or bolt my manual bits from the VP onto it lol.
    3rd time lucky ?
    VrWagz1's Avatar
    May 2008
    wollongong
    maunal t5 from a vp will bolt up to the Vs no worries, but you will need to have the ecu tweeked by doctor bob or i even think greenfoam can do them now and you will need to mod the trans wiring loom of the vs and possibly do somthing with the speedo sensor as i thin its a cable on your car and the VR/S is electronic. Unsure if the pedal box will fit, i have a sneaking suspicion it will
    Reaper
    Jul 2008
    can u be 100% sure about this ? , the VP is a buic and VS is a ecolump...... Different fly wheel balance, not sure about crank bolt pattern or bell houseing bolt pattern.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Dont sound like any of the "go" bits would be worth swapping
    and 3 Dangerous non ABS VN's
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    "Problem, after problem, after problem" - that should be the VN motto. You're not the only one mate. But as Reaper said, you either get over it and fix it or give it to someone who will. I still love my VN... *gritting teeth smile*
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yes balanced differently same bolt pattern on flywheel so youll just need to balance it to match the ecotec flexplate
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. problem with vp
    By elmo_90 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-08-2008, 07:03 PM
  3. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  4. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  5. Problem with car... (im new)
    By Zazzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2005, 09:17 PM
