Results 1 to 11 of 11
Thread: VN V8 Missing when low on fuel
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Default VN V8 Missing when low on fuel
    Ey guys been trying to figure out why my car is missing constantly, I changed the plugs/leads and a full service on the car. Still had the problem, so tryd to pin point what cylinder was missing by taking off the power clip from the injectors one by one, and noticed the idle was more lumpy/grumpy on number 5 and 7. And have pritty much left it how it is at the moment.
    Put 30 litres in last night, and seemed it didnt miss and had my lost power back. Later on in the night when the fuel started to get low(quarter on the gauge) and it had started to miss again.
    So now im thinking its more fuel related, greenfoam who has been a great help trying to pinpoint were the problem is coming from has said it may well be a cracked hose letting air in the system causing it to miss.
    Though has anyone else had this sort of problem? and any help on this would be appreciated.
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Fuel pressure related? If theres a cracked hose then there should be a fuel leak?
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Yeah well you think there would be a fuel leak, but when I ran the car on stands after fitting a new fuel filter I couldnt see/smell any fuel. Just seems it is fuel related as it runs good when theres 20+ litres in the tank.
    VP Executive R-spec
    Jan 2005
    Nah the problem would be inside the tank at whatever fuel level the problem starts at, do you have the twin pump setup on it or single?
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Not sure dude, though I do know it has an external pump if that helps!
    Also when you take the cap off to fill up fuel, you cant hear the pressure releasing from the tank.
    89 VN
    Feb 2009
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by Noy View Post
    Yeah two pumps then, one of them might be dodgy, it should be something wrong in that area anyway
    blaze's Avatar
    blaze is offline ridin dirty
    SILVER BULLET
    Jul 2006
    bunbury
    VP Executive R-spec
    Jan 2005
    If it's only when you are turnin is a problem with the surge tank, with the pump not being line up right or part of the tank come loose etc. But just anytime at low fuel levels will be something different
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Quote Originally Posted by greenfoam View Post
    I can hear it prim when I turn the key, ill have a look tommorow anyway. How can I tell if one them is buggered?
    Cheers guys
    VP Executive R-spec
    Jan 2005
    Fuel pressure test
  1. VQ Missing
    By vpete in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2008, 11:06 AM
  2. Missing 5.0L
    By 5.0L UTE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2008, 09:27 AM
  3. VH for sale, missing eng, trans and fuel tank
    By Typho0n in forum Vehicles For Sale
    Last Post: 24-10-2007, 07:31 AM
  4. Car Missing
    By brownie82 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-02-2007, 02:52 PM
  5. fuel cap's missing what the go
    By burnz in forum The Pub
    Last Post: 28-01-2007, 10:40 AM
