Results 1 to 17 of 17
Thread: central locking diagram for a VN
    VE SV6
    Apr 2006
    Alice Springs NT
    Default central locking diagram for a VN
    does any one have a central locking diagram for a VN?
    wire colours and what each wire does
    i have a VG ute and have put central locking in out of a vq, the wiring plugs were stuffed so i had to put on new ones and now i think i have mixed up where each wire is ment to go
    i am having a problem the lock on my left side unlocks both sides but only locks the left side, the right side locks both sides but but deadlocks when i lock it but it doesnt deadlock the left side.
    i hope someone can understand what i am saying, i think i have the wires mixed up somewhere.
    can someone help with a detailed diagram if possible, the more detailed the better.
    thanks
    Ben
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    The passenger side lock will unlock all but will only lock itself when using the key in the passenger lock if the barrel micro-switch is not connected or installed. It is normally mounted the the inside part of the handle mechanism. The micro-switch is a 2 wire switch
    Now, black/red and black/yellow operate the actuators to lock and unlock. black/blue is the deadlock function and receives +12v.
    Does the door barrel lock in the deadlock position? If so this is your driver's door deadlock as the actuator does not actually deadlock but from VT II on-wards it will. You may not have the micro-switch installed on this either. The micro-switch should be a 3 wire switch.
    Remote locking is operated by orange/brown and orange/yellow from the central locking module and receives -12v (earth)
    Unfortunately I have sold the old VN I converted and do not have the diagrams any more.
    I have also had a malfunction due to the micro-switches being missing and the only way to make the system work again was to put +12V to Black/Blue to dead lock then signal the remote to unlock the locks.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    VE SV6
    Apr 2006
    Alice Springs NT
    ok i undestand what you are saying but my drivers door deadlocks insted of just locking, i mean the acuator deadlocks its self, i have changed it over to one i know works without issue and it does the same thing so thats what has got me thinking it is the wiring
    yes i have the mirco switch installed on the drivers door, it unlocks when i turn the key to unlock, i dont have the mirco switch on the passenger side
    the key lock does deadlock when i turn it 90 degrees anticlockwise.
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    When you say the plugs were damaged, which ones do you mean? Is it the ones that plug into the actuator?
    If it is the ones on the actuator you may have installed them in the wrong position. The only reason why it would deadlock instead of locking is that the Black/Blue wire is in place of one of the Black/Yellow or Black/Red. I believe that Black/Blue remains earthed while the door barrel is not dead-locked but will supply +12v when it is dead-locked.
    The micro-switch is not critical on the passenger door as all it does is tell the system to lock.
    Ok, both front actuators should have a Black running to them which is earth.
    Black/Blue should run from the driver's micro-switch to the front passenger and rear doors.
    Black/Yellow should run to the micro-switches in the actuators on all doors but the drivers will run to the actuator motor.
    Black/Red should run to all actuator motors.
    Brown/Orange should run to the micro-switches in both front doors.
    Brown/Red should only run to the driver's actuator micro-switch.
    Red/Yellow should run the the driver's door handle micro-switch.
    Black/Red will have +12V when unlocking
    Black/Yellow will have +12V when locking.
    The wire information came from a VR manual but seem to match what I remember from the VN/VP system.
    I hope this helps.
    JCCC NSW Member
    VE SV6
    Apr 2006
    Alice Springs NT
    no the door loom plugs were stuffed
    i just matched up the wire colours from the main loom to the door loom wires, i have managed to get the passenger side working right but the drivers side just deadlocks instead of locking so when i turn the key it wont unlock it cause it is deadlocked.
    i find it funny because when i turn the key to deadlock it deadlocks the passenger side without issue, but when i turn the deadlock off it is still deadlocked till i earth the unlock wire, witch i think it is meant to stay deadlocked till it gets the signal to unlock. thats when the drivers side will unlock
    but in the end the drivers side only deadlocks it doesnt just lock.
    my problem is when i bump the lock button on the door it deadlocks and the only way i can open the door is to reach over and lift the passenger door lock to get it to unlock.
    i cant see where i have stuffed the wiring up on the drivers side but even when i swap over the acuators it still does it on the same side, so it cant be the acuator it has to be somthing i have stuffed up on
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    Exactly which wire do you earth?
    To me it sounds like you have the Black/Blue and Black/Red crossing somewhere for the actuator to dead lock.
    JCCC NSW Member
    VE SV6
    Apr 2006
    Alice Springs NT
    i realy dont know what i have done but in the end i just took out the black and yellow wire and now it is working right
    VE SV6
    Apr 2006
    Alice Springs NT
    ok this is pissing me off it all works fine except when you try to use the remote wires and now it only does the passenger side.
    this might be easier can someone take some photos of there drivers side door loom where is conects to the main loom so i can see where each wire hooks up to the other i think i cant get the wiring right.
    this shouldnt be that hard i mean i have matched up the wiring from the main loom to the door loom so eyerything should work with out hassle
    i earthed the brown and orange wire to get it to unlock and the brown and red to lock
    thanks
    Ben
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    try swapping black/yellow for black/Blue
    unfortunately I forgot to take the manual to work with me today to scan in the page. If you can wait until tomorrow I will scan it.
    JCCC NSW Member
    VE SV6
    Apr 2006
    Alice Springs NT
    yeah tried that and it stop working all together.
    i am starting to think there is a problem with the main loom i am using maybe a couple of wires have split and it is shorting somewhere, cant expect much from something that is nearly 20 years old
    if you could get me a copy it would be great
    thanks mate
    cheers
    Ben
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    Here is the wiring diagram for a VR but it should be the same with the exception of the BCM.
    If you need a larger version PM me your email and I will send it to you as its a 2MB file
    JCCC NSW Member
    VE SV6
    Apr 2006
    Alice Springs NT
    VE SV6
    Apr 2006
    Alice Springs NT
    ok this maybe a stupid question but are the actuators the same part for left and right in the front? or are there meant to be two different ones?
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    They are actually three different types.
    You have the driver's door actuator, the front passenger actuator and then the rear door actuators.
    So yes you should have different types for the front
    JCCC NSW Member
  15. #15
    VE SV6
    Apr 2006
    Alice Springs NT
    ok i think i have solved my problem, both of the actuators have the same part number on them, the locks i have are correct for left and right the actuators i think are both for the passenger side because that side is working correctly.
    can anyone confirm if this part number is for the passenger side
    90277866
    and does anyone know what is the part number for the drivers side
    thanks
    Ben
  16. #16
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    Search is your friend, ask and you shall find in another post
    Actuator part numbers
    This confirms you have 2 passenger actuators
    JCCC NSW Member
  17. #17
    VE SV6
    Apr 2006
    Alice Springs NT
    sorry mate i thought i would ask here because i wasnt sure if i was right or wrong on that idea.
    thanks for all your help mate
    cheers
    Ben
  1. Wiring Diagram - Central Locking?
    By mulligan-can in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2009, 09:58 AM
  2. Central Locking
    By anarklov3r in forum Electrical Wiring / Questions
    Last Post: 14-03-2009, 09:00 PM
  3. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  4. VY Central Locking/Alarm Wiring Diagram
    By smyth in forum Electrical Wiring / Questions
    Last Post: 24-06-2006, 10:15 AM
  5. central locking again..
    By warney in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2005, 12:21 AM
