Results 1 to 8 of 8
Thread: Nulon Radiator stop leak
    jakewaze's Avatar
    jakewaze is offline Jakewaze
    VN Spack S1 Auto
    Nov 2008
    Default Nulon Radiator stop leak
    Hi, I have a small leak in my radiator and just bought some of the above and wanted to know;
    Now that the hole is fixed, do I have to flush the system or is it ok to leave it i there??? The botle just says it doesn't harm or corrode the engine, but nothing about leaving it in here long term. Cheers
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    ????? Any Ideas
    I may have broken the law, but that doesn't make it wrong!
    Morton's Avatar
    Fairstar the Funship
    May 2006
    The only thing that stuff does, is find the hole and fill it up. It's a temporary fix for weeping hoses and hairline cracks - it has small bits that get in there and block it up. If you flush the system, you'll flush out the gap filler. I think it also contains an agent to swell up old dry hose ends. I'm not 100% sure on this one.
    I suggest you save up to replace whatever was leaking, while the stop-leak is keeping stuff under control in the meantime.
    The 1972 HQ Kingswood
    VK Berlina
    Apr 2009
    Narre Warren
    A cheaper and less harmful temp fix for radiators is pepper. Course pepper seals up the leaks quick fast.
    1991 VN V6 LE Sedan
    Apr 2009
    Like the other guys posted, this kind of stuff is a temporary fix. There are all sorts of tricks, pepper, egg etc but are temp and are not addressing the fact that your radiator is leaking. Now you know the fault in your system, would probably recommend fixing it now rather then when she dumps the coolant on you 10:30 one night on the side of a motorway.
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    k thanks, i will replace the radidiator asap but hopefully this stuff holds up till then
  7. Default
    how much pepper are we talking?
    (seriously)
    EDIT: don't worry. i was looking for a longer lasting fix than pepper will give (leaking coolant - don't know where from)
    Quote Originally Posted by zai View Post
    I am not sutpid
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    yeh keep it in there, I had a similar leak and this stuff is still holding up after 2months.
  1. rack leaking worth giving that stop leak a go??
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2009, 10:50 PM
  2. leak in the radiator
    By zapper in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2008, 01:43 PM
  3. Radiator leak
    By VT97 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 07:18 PM
  4. Radiator leak
    By killuminati in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2005, 11:55 AM
  5. VK 3,3l: possible radiator leak?
    By bjotob in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-11-2004, 10:30 PM
