Results 1 to 9 of 9
Thread: AC Noise in Cabin - High Pitch Noise
    1991 VN V6 LE Sedan
    Apr 2009
    Default AC Noise in Cabin - High Pitch Noise
    Hello all out there,
    I have just joined the forum and am chasing some information. Yorti (Yor71) is making a high pitch noise that is heard in the cabin when the AC is on. Turn AC off she goes away. It is not temperature related, speed related or load related. Sometimes it will happen and sometimes it won't. Anyone else heard this noise or anything like that? It is deffinantly not a P/S whine (I work for Ford and know what they sound like). Very annoying noise would like a little direction if anyone has it.
    Thanks alot
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    is it in the dash or is it comin from outside.
    I sumtimes get a squeel in mine, wack the dash a few times in couple spots n it stops, i think its like a air accuator closing up n the air still being able to jst get past, good hit n she opens.
    My noises come outta the middle vent...
    Mine will do it ac on or off, soo yea
    not sure if that helps at all
    ________________________________________
    1991 VN V6 LE Sedan
    Apr 2009
    Thanks for the quick post buy its not a wind noise or anything its like a high pitched electrical squeal. Deffinantly inside of vehicle and just suspect centre of dash behind radio.......
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Does it come and go with the compressor cycling on and off, or is it related to the blower motor?
    Check out my VP right 'ere!
    1991 VN V6 LE Sedan
    Apr 2009
    Doesn't change when AC cuts in and out and changing speed of blower motor doesn't change it
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    like a high frequency squeal? Because I have that too.
    Illegitimi Non Carborundum
    camstatic's Avatar
    VP S1 V6 Executive
    May 2006
    Regional SA
    Sounds like it could be the whistle of gas through the system...
    1991 VN V6 LE Sedan
    Apr 2009
    Nah not a whistle of gas it is like a high pitch frequency like a piece of electronics is making the noise - very bizarre and annoying.
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    Default i have the same issue
    mine starts to get a high pitched sequel after a few minuets from under the dash stops when the ac compressor kicks in or out i was told by an ac repairer it is most likely due to the ac being a touch low on gas causing tiny vibrations through the piping under the dash and not to be worried its common
    having said that in summer it can bring a huge migraine on but who cares when its hot as long as its cold i don't complain
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
  1. changed brake pads but have high pitch noise
    By gazzabrizz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2009, 08:03 PM
  2. cleaned cia on vr now high pitch noise wtf ?????
    By adz86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2008, 01:26 AM
  3. High pitch noise @ high rpm
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2007, 10:00 AM
  4. alternator high pitch noise
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2006, 05:23 PM
  5. Question????? - Exhaust noise level and pitch
    By cameron boyle in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2005, 10:01 PM
