Here is a list of numbers that can be used to work out what Level 3 trip computer you have in your Commodore.
VN GREEN 88 39449
VN GREEN 89 39449
VN BLUE 91 40748
VQ BLUE 91 40748
VP RED 92 40748
VR GREEN 93 44378
VR GREEN 94 44378
VS GREEN 96 44378
VS LT GREEN 98 44378
This number is stamped on the main ODO chip inside the trip computer.
Here is a link to Calibrating your trip computer
VN L3 Calibration - How To!
and 3 Dangerous non ABS VN's
Thanks
have few odd things with my dash, been wondering if it was for a vn or not.
What exactly is this useful for?
I put together 2 different damaged levels 3 dashs.
Now I can tell what model the donor dash was from.
Some other info.
You can swap the Series 1 LCD screens (thin numbers) over with fat numbers (Series 2) - but they must go in the same spot - as in the middle LCD must remain in the middle - as with the left and right LCD screens.
I also have a complete set of ID's for the cluster PCB (plastic bit on the outside). Lens too.
Post up any questions![]()
thanks heaps for this shane! you know the trouble i went through with my trip computers haha
should be a sticky![]()
You come up with all sorts of fantastic info Shane, you're a legend. You should start up your own commodore tech website![]()
The 1972 HQ Kingswood
OK found out that the VR trip computer is very different from the VN/VP/VQ units. The speed alert and low fuel are incorrect and will not function correctly.
Fit a VR trip computer to a VN/VP/VQ = FAIL. trust me I know![]()
haha yeah, i don't think i ever told you that my speed alert never worked with the vr trip... which is why i thought it was a speed sensor not sending a signal, no cruise and no alert.
Here is some info on how to identify S2 VQ V8 tacho and temp gauge
So if the trip computer is from an vn, and the rest of the cluster is from a vr its a fail?
I get odo, dist till empty, etc but the but every time I turn the igintion off, the computer loses that info and recalculates when its turn on again, plus a few other minor issues.
I had to do a solder job on the copper tracks on the back of the cluster, to jump burnt sections.
The VR PCB on the back of the cluster is different - even if you change the wires to suit the VN wiring pin out the regulator feed power different. TheVR cluster only has 9 pins into the regulator - the VN has 10 and the low fuel and speed alert is opposite.
The VR gauges will work in a VN cluster. If you fit a VN PCB & regulator your problem will be fixed - thats my guess.![]()
