Results 1 to 9 of 9
Thread: power steering fluid leak
    VP Exec
    Mar 2009
    Melbourne, bayswater
    Default power steering fluid leak
    Hi guys, i am pretty sure that i need a new steering rack. But before i go buying one i want to make sure that thats the problem.
    I noticed acouple drops of power steering fluid on the garage floor. Kacked the car up today but i couldnt see where it was comeing from. Replaced the power steering pump around 3 weeks ago.
    The steering is abit stiff also.
    What you guys think?
    Vp series 2
    Jun 2008
    mate look harder for the leak then let us know.
    loose hose, connection, worn seals spilt fluid leaking down from k frame trany leak.
    take your pic.
    VP Exec
    Mar 2009
    i have looked everywere and cant find anything. My best guess is its from one of the hoses, but wouldnt have a clue if its them or not.. there is a allen key bolt on the steering rack. Whats it do? If i unscrew it what would happen? Just curious.
    Thanks Terry
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Dude, check the return hose! Try to tighten the hose clamp where it joins onto the metal fitting at the rack. If you cant tighten it anymore then the hose is ancient and has shrunk under the clamp (the clamp wont tighten past a certain point).
    Thats where all my fluid was coming from, and your car is 3 years older!
    If that fails, check ALL the fittings, clean up the rack then watch where it leaks from.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VP Exec
    Mar 2009
    I know which metal fitting your talking about but how the heck did you get there? I tryed it today but my fingers are to big lol.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    how do the rubber boots look on each end of the rack ?
    if you run your finger around all the suspect bits you should find where the leak is... by the wet spot.
    VP Exec
    Mar 2009
    It has been leaking for quiet some time. When i replaced the power steering pump alot of fluid ran down onto the rack. So the whole thing is pretty much wet, I cleaned it up today and will take another look at soon.
    VT Acclaim 98
    Jun 2009
    Hi
    i read on this blof about lucas power steering fluid leak stop.should i mix it with alredy filled steering fluid reservoir ....or how should i do it..
    please help
    sachi
  9. Default
    What do the instructions on the bottle say? Stop leak is generally an additive and not a replacement. Just make sure you don't overfill the reservoir.
    Quote Originally Posted by zai View Post
    I am not sutpid
  1. Power steering fluid leak - VP
    By LoZzA199 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2009, 11:34 PM
  2. Power steering Fluid leak
    By 410ci in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2009, 02:53 PM
  3. Power Steering or Transmission Fluid leak?
    By DzRBenson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2008, 10:05 AM
  4. VN power steering fluid leak
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2006, 11:23 PM
  5. Power Steering Fluid?
    By Cody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2005, 03:58 PM
