Results 1 to 12 of 12
Thread: Vp 5litre
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Thumbs down Vp 5litre
    hey my mate put a vp 5litre engine into his car
    as far as well all know its done 100%
    new parts where easyist
    but there is a problem
    the oil seems to get blocked, have done 6 drains and refills, and a new oil pump
    does anyone know what it could be?
    thanks
    COMMODORE VP
    Dec 2008
    old oil blocking the galaries i recon
    but not sure how to fix or what to do
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    is it not getting oil pressure or something
    COMMODORE VP
    Dec 2008
    yeah no oil pressure, did have put dont know, what are the best methods to get oil pressure back, already replaced oil pump
    в∞ѕтεכ √&
    Jul 2008
    NZ
    did you bleed the pump at all.it should suck up enough after a few seconds anyway.havnt left any bungs out of anywhere.pickup in the sump not blocked.
    COMMODORE VP
    Dec 2008
    nah didnt bleed pump, just replaced
    does vp 5litres have a pressure regulator?
    is it internal of the oil pump or behind/next to sender
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    The oil pump is what the oil filter attaches to. You need to cake the gears with Vaseline to get the thing to generate enough suction to get the oil out of the sump. Once it is primed you are fine. Have you checked that the sender/gauge etc is functioning correctly?
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    COMMODORE VP
    Dec 2008
    so the oil pressure regulator is part of the oil pump?
    yeah the gauges are fine and senders etc
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Is it possible that your oil pickup is blocked? On rare occasions chunks of crap can fall down into it and cause issues. Pain removing the sump to check, though.
    The 1972 HQ Kingswood
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Reaper
    Did you do this when you put the pump in, if not then thats why you have no oil pressure.
    Reaper
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by COMMY VP 666 View Post
    You have physically checked or you just know?
    Reaper
    Reapers Black VP SS
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    regulator ie relief valve and spring are built into the pump I suggest you prime the pump and remove oil pressure sender and fit a mechanical pressure gauge to that spot best way to check physically that you have oil pressure
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  1. [SA] wrecking vq 5litre
    By sus_calais in forum Parts And Other Items For Sale
    Last Post: 06-05-2009, 12:02 AM
  2. vs 5litre cam
    By Bode88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2008, 07:09 PM
  3. statesman 5litre LSD??
    By adrian222 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2008, 12:53 PM
  4. VL 5litre on NOS
    By SSVZ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-01-2007, 02:34 PM
  5. Vt V8 195 I 5litre V8 Bcm Problems
    By Rock56077 in forum Electrical Wiring / Questions
    Last Post: 29-02-2004, 09:33 PM
