for coolant
on the side of the block is there coolant drainage plugs?
or have to do it another way?
there are welch plugs, what are you trying to do exactly tho?
coolant drain
thanks
u sure there the welch plugs, isnt it a lil one in the middle of them?
if your coolant is that bad then you would be better off flushing the system then refilling with fresh water and the right amount of concerntrated coolant.
yeah thats my plan, flush till water comes out clean, drain, then re-fill 50/50
Run a garden hose or a large funnel into one of the radiator hoses (with the thermostat out) and pump craploads of water through. Then do a reverse flush.
Then fill up with a bottle of coolant flush concentrate and tap water, close the system (still without thermostat) and run the car for half an hour. Turn off, wait to cool, flush the entire system again as you did before.
Then if it's particularly bad, fill with coolant flush and do it all again.
The 1972 HQ Kingswood
