Results 1 to 7 of 7
Thread: Help, DOes any one know - easy
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Thumbs down Help, DOes any one know - easy
    does anyone know where the
    oil pressure regulator is on a vp 5litre
    let me know thanks
    Vp series 2
    Jun 2008
    COMMODORE VP
    Dec 2008
    by any chance is it part of the oil pump assembly
    like when you change the oil pump over, it also changes over the "oil pressure regulator"
    VQ Caprice II
    Aug 2006
    On all 304's Holden 5 Litres it is a screw in module located on the oil pump.
    Should be a slide on clip from the loom that connects to it.
    http://forums.justcommodores.com.au/...-setup-001.jpg
    this picture shows the oil pressure sensor, but they have added another electronic using a t-piece. Best pic I could find quickly.
    hope this helps.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yup, should be screwed right in on the oil pump, and you'll find it just behind the oil filter. If you can find the oil filter, you'll find the pressure reg no problems.
    The 1972 HQ Kingswood
    COMMODORE VP
    Dec 2008
    hey thanks been heaps of helps
    how many wires are going to the oil pressure regulator
    and what are they coming from
    does anyone have a wiring diagram for the oil pressure regulator
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    pressure regulator doesnt have wires but the oil pressure sender for the oil light does
  1. How easy is it to?
    By vrgurl87 in forum General Discussion
    Last Post: 06-05-2009, 10:10 AM
  2. Easy one
    By COMMY VP 666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-12-2008, 11:52 PM
  3. I need help !!!! Easy $100 US
    By doyle4281 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-11-2006, 01:42 PM
  4. An easy fix?
    By SL/ENUT in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-02-2005, 03:41 PM
