Results 1 to 4 of 4
Thread: VN cranks but has no spark ...
    VN
    May 2009
    Default VN cranks but has no spark ...
    Hey guys, my friend has a VN V6 and for a while it had intermitant starting, somtimes it would start somtimes it wouldnt, and now it just cranks and has no spark at all.
    We jumped the black /white wires near the computer and we get 4 flashes, then a break, then 1, so we assumed this was a code 41 which saiz its the crank angle sensor, so we replaced that yesterday and its still cranking and has no spark.
    Also after we replaced the crank angle sensor we still get 4 flashes then 1, does this have to be reset or does this mean there still is a problem?
    Anyone have any ideas of what may be wrong?
    Thanx in advance guys.
    Vp series 2
    Jun 2008
    remove the engine fuse for 30 seconds and try again.
    could be plug left out or broken wire to cas to.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yes best to disconnet the ecu for a bit mine did this same thing when i changed the cas
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    it can get that code when the dfi under the coils dies too so if its still there after an ecu reset check the plug on the dfi and then replace if its no better
  1. cranks and starts but loses its spark?
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-09-2008, 10:05 PM
  2. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  3. cranks but no spark. please help !!!!
    By vks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2006, 01:16 AM
  4. cheap 355 cranks
    By billetute in forum V8 Development and Modification
    Last Post: 23-09-2005, 11:54 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
