Results 1 to 7 of 7
Thread: sweet harmony
    VN Commodore S V6 series1
    Dec 2004
    Default sweet harmony
    Hey guys was just woundering how one goes about changing a harmonic balencer on a VN v6 series1.
    Commodores where do you want to go today
    I have a 'couple'
    Jan 2005
    Bris
    You need to undo the bolt through the centre which can be a tad tight!! But you will most certainly need a harmonic balancer puller. It screws into the holes infront of the balancer and is the only proper way to remove one.
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    BAH u dont need no puller
    if you have a rattle gun (not a battery one) then crack the nut with that
    otherwise you need to drop the torque converter cover plate (auto) or the flywheel cover plate (manual) and get a strong bar (jimmy bar works ok) to stop the flywheel from turning then you can crack the nut
    now the nuts off take the balancer off... some models slide freely off no worries others do require a puller however... since you are replacing the sucker you can get two crowbars behind the bish and lever it off rather than buying a puller with parts that get lost easily lol
    rattle gun make life alot ezier considering how hard that sucker is to crack by hand (if you do do it by hand use a stong metal bar over your breaker bar to crack it)
    VpV6 is offline Banned
    VP II Executive
    Feb 2005
    Rattle gun off the nut... that will save you lots of time!
    You can pry it off with the crowbars, but id be a bit worried about damaging the timing cover behind it. Best way is to spend $10 - $15 on a harmonic balancer puller. You then just line up the puller and screw in 3 bolts, then turn the centre worm until it pops off.
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    exactly ..
    confuscious say, dont use a jackhammer when a chisel will do .. ^_^
    never late in a 3 0 .. uhhh ... intercooled turbo
    yes i drive an mx6 turbo ... its probably quicker than yours.
    Dec 2004
    cheers guys il give it a wack on saturday, thanks for all the info sounds easy enough, and i think my dad has a puller to help it off.
    cheers again.
    VN Exec
    Oct 2004
    Langwarrin, Vic.
    Do you all beat the hell out of your motors when you work on them?
    There are two types of pulleys on the VN S1, and they are simple to check.
    Either way, you need to get the bolt undone and a rattle gun would seem the quickest and easiest option. Although I managed to undo mine by giving a spanner a few hard sharp hits with a hammer to crack it.
    If your balancer has the bolt holes for the puller, then use a puller, as it is a tapered fit and designed to be puled off using the right tool i.e. a puller.
    If it doesn't have the puller holes then it is the straight shaft type and should almost just slide off. If not, some gentle but firm work with a couple of 15" screwdrivers should work it off.
    By all means get stuck into it with bars etc, but be prepared to live with any damage that results. The right way, first time may save you lots of grief.
  1. How sweet is this!!!!
    By nicko in forum The Pub
    Last Post: 16-12-2007, 09:54 AM
  2. sweet fiat
    By commyvx in forum The Pub
    Last Post: 19-03-2007, 05:32 PM
  3. harmony...lol..
    By rattattack1313 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-06-2006, 11:48 PM
  4. sweet as vh
    By YoungOne in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-10-2005, 10:51 PM
