After driving a short distance this morning i noticed the leak. The car drives fine but when i looked under the bonnet it was spraying trans fluid from somewhere by the dipstick. Does this mean my trans is blown or could it be a gasket leak somewhere. Any help would be great..
i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
http://robsbackyarddragraceing.bigblog.com.au/index.do
yes pretty sure its trans fluid
There the same fluid.
I also think its the power steering fluid. The hoses are prone to spraying when they split, mine sprayed directly onto the extractor tho....
Originally Posted by davway
if its the original hose thay have a tendency to dry and crack because of the heat of the manifold just check it trust me its worth it and if you cant see a crack or split have a look in the power steering pump for the level if its low that will be it i only suggest this as it would be odd to see a spray from that area of the box good luck![]()
thanks guys i hope its only a hose to. will have a look in the morning .
keep us posted![]()
trans has a little bit of rubber hose at the front near the radiator. if it is up the drivers side then i would guess power steering to.
i just got a pm from brianbee turns out the hose for power steering had loosened off and completely popped off another problem solved![]()
