Results 1 to 11 of 11
Thread: Reasons the TCC won't engage
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Default Reasons the TCC won't engage
    Torque converter won't lock up. I'm a bit over poking and prodding things on the car, just done a motor swap. Anyone able to point me in the right direction to find the plug I have surely left out?
    Sam
    WTB: mulberry VN interior parts
  2. Default
    what's the temperature like when it's running? coolant temp sensor might not be working correctly. the torque converter only locks up when the coolant temp sensor is reading above some certain temp, and if it's reading too cold, it won't lock up.
    Quote Originally Posted by zai View Post
    I am not sutpid
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yip coolant sensor needs to read right .tps sensor volts need to be at a certian amount ,speed needs to be above 80+km/h.kickdown adjusted.fuses all good.temp switch on trans plugged in
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Mine wasn't engaging for a while, after poking around for a decent amount of hours on it, it turned out the clutch itself was stuffed and it was just slipping when it was engaged anyway.
    Check out my VP right 'ere!
    vnss
    Jan 2005
    s.e melb
    didnt greenfoam start a thread a lil while ago about the sam eproblem?
    turned out his ecu was the culprit
    camstatic's Avatar
    VP S1 V6 Executive
    May 2006
    Regional SA
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    will check that trans temp switch... where do I look, on the trans itself?
    Unlikely, the TC is only young, new one with rebuilt auto about a yr ago, worked fine with old motor
    didnt greenfoam start a thread a lil while ago about the sam eproblem? turned out his ecu was the culprit
    My ECU is the same one that was running fine on the old motor.. locked up every time at 90kph
    Really need to log it and see if it's trying to engage.
    Checking the fault codes do the trick?
    VP Executive R-spec
    Jan 2005
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Check your battery/reg because if the computer is not getting enough power then this can also cause this.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Replaced TPS and coolant temp sender (ECU one), still no lockup
    Next thing I will check is that I have actually plugged in the TCC
  1. Power required to engage boot solenoid
    By Pub247 in forum Electrical Wiring / Questions
    Last Post: 14-09-2008, 04:36 PM
  2. Auto trans doesn't engage lower gear
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2008, 02:56 PM
  3. Replies: 2
    Last Post: 22-10-2006, 12:15 PM
  4. Highbeam doesnt engage!
    By Gem713 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-06-2005, 07:47 PM
  5. Delay for reverse to engage
    By electradaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2004, 09:31 AM
