Page 5 of 5 FirstFirst 12345
Results 101 to 110 of 110
Thread: opperation turbo vp v8
  1. #101
    vp 5L
    Jul 2008
    goldcoast
    Quote Originally Posted by vp_304 View Post
    nice resaults
    what exhaust does the car run 3 inch single system ?
    or twin 2.5 inch?
    single 3 inch from turbo
  2. #102
    Jan 2007
    thanks for all the info mate.
    any bits i should watch out for when building my setup?
    pritty much same as yours same turbo motor etc etc
    how manny k's had your motor done? is it all stock ie motor internals gaskets etc ?
  3. #103
    VY SS
    Jun 2006
    Albany
  4. #104
    vp 5L
    Jul 2008
    goldcoast
    best advise i could give u is who ever is making the manifolds make sure they know what they are doing and only use 3mm steam pipe , everything is a compremize wen putting a turbo into vn -vp eg the manifolds have to made so u can access the spark plugs and the bolts to bolt the manifold to the head , even the manifolds i had made still make it every hard to get the plugs in and out and also u have to alow for where spark plug leads are going to sit , i had to have custom leads made with right angle ends on them with heat socks so they wont melt, u will need to extend the factory wiring a little bit not that hard to do , i relocated the ignition modual behind the head light witch didnt need anything cut, the oil drain needs to be plumbed back into the sump , u will need to remove the sump i welded a fitting right beside where the dip sitck goes into the sump , just be carefull were u mount the turbo becuase u have to have room for a air filter and intercooler piping and also bonnet clearence
  5. #105
    Jan 2007
    do u remeber how big hose you used on the turbo return oil line?
  6. #106
    vp 5L
    Jul 2008
    goldcoast
    just an update from the owner of my old car back on the dyno and 340hp at 8psi , he tells me hes putting on a come racing twin throttle body manifold this thursday
  7. #107
    Jan 2007
    wasting his time with the manifold change ive seen 2 355 turbos run 10's on the standard manifold with boost.
    any reason why you sold it for mate?
  8. #108
    vp 5L
    Jul 2008
    goldcoast
    i dont dought u for a second but what people do with there money is there own problem , no matter how much advise u give people they always like to learn the hard way , i just sold it coz i wanted something newer , now i got a vx ss , its a good car but i still would like something else maybe a vy vz, also the new owner told me it blows the tyres well into third gear, makes me think i should have kept it
  9. #109
    Jan 2007
  10. #110
    VN SS
    Aug 2009
    is your mate interested in making another one of those manifolds?
  1. sts turbo (rear mounted turbo under car) what have you heard?
    By shwarno in forum V6 Development And Modification
    Last Post: 01-06-2010, 09:46 PM
  2. Super Charger, Twin Turbo Or Single Turbo On My Vx Need Suggestions
    By GMHG3N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 11:38 PM
  3. GROUP BUY TURBO - GENUINE GARRETT TURBO GT35/40R 700Bhp
    By GTS1963 in forum Parts And Other Items For Sale
    Last Post: 21-12-2006, 12:14 PM
  4. Confused and unsure...turbo/supercharger/stock turbo?
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 09:51 PM
