+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 26 to 48 of 48
Thread: 1990 VN "S" Manual - First Car :D
  1. #26
    VN S Manual
    Jul 2009
    Oh that im with you, yes currently it is sitting like that but only while im not driving it, the reason i havent put the back wheels on is they hae 265/35/18 tyres, which apparently wil no way fit under the back nd of a vn guard. so im gonna sell of these tyres, one brand new never used and the other 90% as well as the two near new fronts and get a matching set of 235/40/18.
  2. #27
    VN S Manual
    Jul 2009
    Also update, without pics but they will follow.
    I have fitted my rear seat, had to weld up a few brackets and make up a catch for the centre seat but it worked out pretty sweet
    I have finished installing my centre console and stereo surround.
    I have fixed up an assortmnt of broken mounts, such as cluster surround, fuse panel locating mount, as well as a few oter things.
    Got a problem with my interior light, it seems that if i have the rear map lights plugged on just the drivers side, as well as the center interior light, when i push the passenger side dome light it brings the on bulb for that aswell as the center festoon light, if you know what i mean. im hopng i have just plugged some stuff in wrong. the only lighting wire tampered with was the one to cnnect up the calias level three sitchblock, and the interior light buton is working perfectly.
    any ideas anyone?
    lastly found the following,pick up this week sometime.
    Console power window switches
    mirror joystick
    vn ss centre peice (as mine is damaged)
    rear rooflining panel
    window module
    and harness for power windows+mirrors
    all for $100
  3. #28
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    looking good !
    NEED MORE PICCIES
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
  4. #29
    VN S Manual
    Jul 2009
    New update!!! no pics at this stage though....
    Have installed power windows and mirrors, have the backs working perfectly, fronts i am having trouble with the mounting the regs on the window. Ive kinda got the drivers side working but its not right isnt going up as smooth as the back, and also window is mounted on runners right as it falls a bit
    I recieved my splits! SPL Dynamics 6.2, they look really cool! should sound awesome to!
    I ran my amp power wire yesterday, and tomorrow im getting the rust in the boot welded up, so it will be water tight!
    Following this is my much awaited boot intsall, will only be simple but will be so much better. a new mdf parcel helf will also come with cutouts for some 6.5 inch speakers, that wil just run of the headunit.
    will also mount the amp and speakers once rust and windows are done.
    I have put in an electric aerial, somebody decided they wnated my old manual one pretty bad.
    things are coming along, moneys an issue though....
    90 days till my 18th!
  5. #30
    VN S Manual
    Jul 2009
    This is what im thinking of doing for a boot install:
    The black square is the amp for my splits, The green squares are hinges, my plan is to hinge that area so i can store a jack and a sidcrome kit in there, jumper leads, wheel brace.
    I wanna not build a section up, so the bit in red imagine it isnt there. i was thinking a sub box in there, with my sub amp mounted some where in the same spot?
    anyone else got anby ideas?
  6. #31
    VN S Manual
    Jul 2009
    Changed my idea on the boot install. Just a few more progres pics,
    bogged up a few rust holes, still have to sand and paint.
    Pic of rear seat installed, and my door trims, however they turned out pretty shit.
    front while i was installing power mirrors and windows. Still need a drivers reg if anyone has one as mine is stuffed.
    and a motor pic, have added a cold air intake, still need to just tidy it up, hit it with some degreaser.
    Got my eye on some vq stuff, rear bumper and skirt, chrome striping, vn ss front with vq chrome grill
  7. #32
    VN S Manual
    Jul 2009
    Just finished making my new parcel shelf. turned out pretty well i think
    Havent fully finished installing it as i still need to fix my rear demistor wire on one side, snapped the dam metal tab!
    did a write upin this thread. : http://http://forums.justcommodores....l-shelf-2.html
  8. #33
    VN S Manual
    Jul 2009
    Major Update!!!
    I GOT MY P'S!!!!!!
    I have the 18's on with new tyres
    Front door Trims are in
    Rear Demistor is fixed.
    Rear seat reinstalled, better fit.
    parcel shelf updated with splits.
    Chrome trims half put on
    Have my eye on some amps to power my front + rear speakers
    and i am building my sub box after exams all cut out and ready to go
    Oh and some power window issues ironed out. left rear has stopped working though!
    Still a lot to do howerver its all slowly coming together.
    I also got some pics for you all, as i got a camera for my b day
    Only outside pics will get some inside ones asap
    Had the front end jacked, whoch lowered the rear so i took a pick, i wanna get the rear end sitting like this, any idea what sorta springs i should be looking oat? gonna do all the rear suspension soon
    as you can see i havent quite finished off the vp calais chrome trims lol getting there though
  9. #34
    VN S Manual
    Jul 2009
    Also i nearly have all the body peices needed to rid my car of the ugly vp-ness for ever!
    I have a vq rear bar with vn ss 3 peice lower skirt, and a vn bar,
    -still need a vn ss side skirts and a front sqirt as well as a vq garnish should look good when done through
    Possibly thinking some vq spats to
  10. #35
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    looks heaps nice, i like it . . as for the springs question im guessing kings ultra lows *anyone correct if wrong* but you can get rear set of ultra's on ebay for $150
  11. #36
    VN S Manual
    Jul 2009
    Ive finished off the chrome trims and installed some new audio stuff.
    Purchased a Zylux Alarm system RRP $350.00, got it through a mate whos a rep for $155.00! That will be going in this week, as well as a 1000wrms reponse mono amp, and a 1000wrms Mach 5 12 inch sub in a custom box.
    Need to start working on paint soon, do the roof, my vq stato bumpers, and all my vn ss skirts ect. Try to locate a vq garnish.
    As for the springs im worried ultra lows are gonna make it undriveable, ive seen some cars dragging ass so bad when on ultras, most of those have had stockies on though, anyone have any experiences with ultras and 18's?
    Thanks for your comments 10WVN, your cars looking pretty decent to!
  12. #37
    VN S Manual
    Jul 2009
    Also might be changing my seats again, so if anybodys interested in a Vy executive rear seat in excellent condition, with modified base and side sections, with custom brackets, all bolts included to install, direct 10 min install let me know Also have a matching passenger seat i could throw in for a bit extra
  13. #38
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
  14. #39
    VN S Manual
    Jul 2009
    Im in Gippsland, Victoria. Looking for around $150.00 for the complete back seat and the passenger seat.
    The rear base has been modified to mount into original vn mounts. The two side peices have had custom brackets with bolts welded to seat frame. these bolts go through the round hole found on all vn/vps. the only thing you need to do is bolt the fold down centre part, this is best done with self tapers and takes five minutes.
    The passenger seat is in great condition however is missing the map pocket, can be purchased cheap though.
    If your just after the rear i can do it for $100.00
  15. #40
    manual vn commodor . turbo might be cool
    Jan 2010
    in the yarra valley
  16. #41
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    Quote Originally Posted by gen3 View Post
    were you get the sticker from
    i guess your talkin bout the JC sticker?
    JustCommodores Stickers
  17. #42
    VP S Pac
    Jun 2010
    Bathurst
    Looks good mate, wheels suit the car, very nice.
    Ease up on the ugly VP comments though
  18. #43
    vn s pack 5spd/ vs calais S1
    Apr 2010
    looks nice man
    i also got my self a vn manual for $850 n few fixing up 2 get it on the road
    im interested in seeing how your doors looked ? iv jst finshed doin my doors blk gloss wit red
  19. #44
    VN S Manual
    Jul 2009
    Thanks for helping that guy out with the sticker
    Ill ease up a bit on the vp comments, just not a huge fan of the bumpers compared to a vn ones.
    Ill grab some pics of the interior for you, im not one hundred percent happy with the doors but ah well it will do for now.
  20. #45
    VN S Manual
    Jul 2009
    some up to date pics including interior/door trim
    also some reflection ones
  21. #46
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    wow its looking heaps nice.. love the seats . . trims look good too, what material you use?
  22. #47
    VN S Manual
    Jul 2009
    the white parts are the original door cards retrimmed in white vinyl. i then dyed the trims using vht dye and added vs door pods with black carpet along the bottom. The front seats are actually for sale with a matcching rear and the matching door trims. as i will be adding vy seats to the front to.
    Thanks for your comments guys, once i finish off what i wanna do to the outside it should look heaps cleaner!
    Doing the boot install this holidays and tidying things up.
    also in the process of saving for my weekender, a single cab 2nd gen (84-89) hilux, will be mad, 33's, custom tray, paint the cab a cool colour
  23. #48
    Apr 2010
    nice ... iv posted up my interior pics .. jst the doors are dun atm
+ Reply to Thread
  1. Replies: 13
    Last Post: 26-03-2009, 05:34 PM
  2. Best "Hero" Colour 1990-present.
    By Jaime S. in forum General
    Last Post: 10-01-2009, 12:06 AM
  3. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 05:59 PM
  4. Starcorp Impul Wheels 18"x8.5" and 18"x9.5" Adelaide
    By vs_ss_matt in forum Parts And Other Items For Sale
    Last Post: 24-05-2008, 05:43 PM
  5. Is the warning "service engine oil" the same as "check oil" ?
    By morris in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2006, 04:36 PM
