Results 1 to 17 of 17
Thread: Just another blue wagon, VN '90
    '90 S1 VN 3.8L A4 Wagon
    Feb 2009
    Cool Just another blue wagon, VN '90
    1990 VN Executive Wagon
    Basics:
    -Dark Blue
    -Auto
    -210,000kms
    -V6 3.8L
    The Different:
    -new front discs + VP HSV brakes + 1 & 1/8th master cylinder. (better but not great)
    -Roh 15x7 +35 running 215/65/15 continentals, painted (canned) gloss black.
    -powerchip installed back in early 90s
    -series 2 coilpacks
    -crappy old clarion headunit
    -2x4" sony speakers (only 1 works, wiring problems)
    -CAI, from bunnings
    -removed rear muffler, replaced with straight 2.5" pipe. (isn't loud, way under legal limit)
    -wire holding on the rear pipe - rubber hanger needs replacing.
    -random cheap, black seat covers.
    Replaced:
    -Automatic gearbox, replace with 2nd hand unit @ 205,000kms. (unsure of kms on the -2nd hand unit, however, huge improvement from the old unit can hold gears now )
    -rear boot struts
    -radiator
    -power-steering pump
    -LHS indicator x2(one was vandalism), LHS headlight x 1, LHS rear taillights x 1 (damage)
    -LHS LCAs, 1 wheel, steering rack and other parts around that around (damage)
    -both LCAs(dodgy mechanic source bad parts)
    -rear bumper (damage)
    -drivers seat and drivers seat rails
    -thermostat
    -throttlebody
    -heatertap
    really isn't my car, just my parents but i mostly drive it these days. Since i'm saving up for a real car, haven't spent much on the VN. I decided to go for a different look. 20" chromies is not my style and its so over done these days and considering i have moved over to the import scene, decided a more aggressive styling would be a welcome change to the car. If i was to spend some money, most of it would go into upgrading the handling.
    Future plans:
    -fix fuel economy(#1)
    -fixed aircon
    -tint rear windows, quite dark. (rear doors onwards)
    -might get a slight tint on the front door windows.
    -address positive camber wear problems.
    You're probably wondering where you are. I'll tell you where you might be. You might be in the room that you die in. This is your wake up call.
    Feb 2009
    old picture: forgive me, the white stripe wasn't my idea. it has now been covered with black tape. rims are also black atm.
    custom CAI + dodgy air horn.
    engine shot, you can see the mesh to stop leaves building up near the windscreen.
    ill get some more recent pics up when i have the time. (so not for a while.)
    VN WAGON
    Sep 2007
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Wagons FTW. Looks in good nick. I like your duct tape and plastic strap work
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Quote Originally Posted by meanvn View Post
    not a bad wag mate. i have a blue vn wagon and there unreal
    BAH! THERES NOTHING VN LEFT ON IT...
    to op, nice colour, you got lucky in that area, there were some shocking colours in the VN range.
    That c.a.i go to under the front bar. looks like a good home job.
    The Black Beauty
    skruba is offline holden, honda, pitbulls
    vp executive
    Jun 2009
    parkes nsw
    Feb 2009
    Quote Originally Posted by TVR-161 View Post
    and compared to some VNs, the paint is mostly alright, considering its age and the fact is has been living out on the street since '04.
    I can't seem to find a place to get the CAI into the front area, there isn't enough room. I had a look but unless i can something my pipe wouldn't fit. got a picture of your setup or a setup you know of?
    The pipe came from my front yard, dad was using lots of it for grey water to water grass, so i cut a bit off. was large enough and strong enough for the job.
    Feb 2009
    radiator fan stopped working today. car is running hotter then normal. i suspect it's faulty wiring.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Probly just the connection, unplug it clean it and plug it back in, or also check the fuses/relays.
    ~ VN POWER ~ Click the scales
    Feb 2009
    forgot to add, bonnet release latch is also broken. what great timing :P
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Mines on its way out, just needs abit of adjustment, be a lil bit of a price is it broken and the bonnet is shut? its not to hard grill out and get some tools flat head screw driver and pointy nose pliers and get the wire
    Feb 2009
    yeh bonnet is shut. should be able to open the bonnet but how do i fix the latch?
    Feb 2009
    fixed the latch, wasn't really broken. fan is working atm, so that ll be addressed later.
    left the front windows open all night last night spent half the afternoon stripping the front interior to dry it. passenger seat aint bad however, drivers seat is soaked. should be fine within a week.
    Dec 2007
    Feb 2009
    there goes the auxiliary belt. should be fixed by tomorrow. i hope.
  16. #16
    Feb 2009
    auxiliary belt replaced at no charge, the local mechanic didn't tighten up the power steering pulley enough.
    interior is dry, carpets will be put back in soon.
  17. #17
    Feb 2009
    interior back in, that whole fk up cost me at least 6hrs. however, far more careful now.
    might wash the car this week and post some pics up.
  1. Barbados Blue VZ Wagon
    By andyman in forum VY - VZ - WK - WL - V2
    Last Post: 30-04-2012, 12:44 PM
  2. Beralds Blue Vp Wagon
    By King_berald in forum VN - VP - VG - VQ
    Last Post: 14-05-2009, 10:26 AM
  3. Blue drive in 92 berlina vp wagon??
    By va23boam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2008, 03:27 PM
  4. Selling - VB Metallic Blue Wagon, 202
    By haloeight in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-11-2005, 11:31 AM
Tags for this Thread
