Results 1 to 23 of 23
Thread: My VN V6 dragcar 'project-101'
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    Default My VN V6 dragcar 'project-101'
    Here are some pics of my 1990 VN sedan project car.
    Future mods:
    -VN-VR V6 4.2 Stroker kits...BOOST application kits with the absolute strongest parts available anywhere for the Holden V6 engines. These balanced kits feature our 4340 steel billet stroker cranks, our 4340 steel "H" beam rods with ARP2000 series bolts and either Wiseco or Diamond Racing custom forged pistons, moly rings, rod and main bearings all for $5000.00
    - chemically cleaned, crack tested, bored, decked and honed block
    - Champion aluminium aftermarket big-port heads
    - Yella Terra hi-ratio roller rockers
    - deleted balance shaft
    - one piece pushrods
    - solid roller cam and lifters
    - twin row timing chain set
    - ASR Drag-comp oilpan
    - modified oiling system see: (cant find appropriate link!!)
    - custom fab'd tubular turbo manifolds
    - GT37 with GTP turbine wheel, .68 rear housing
    - 3inch turbo - back exhaust
    - 600x400x75mm front mount
    - 3 inch intercooler/intake plumbing
    - T400 full manual with 3500rpm stally (just got a quote, was like $5400!)
    - 3.9:1 mini-spooled VK/VL BW78 diff (50mm shorter than std. VN BW78 diff)
    I'm sure i have forgotten a few things, will update accordingly!
    My super awesome workspace!!!
    vn v8 berlina
    Dec 2009
    Jan 2010
    Bendigo, Victoria
    Jan 2010
    Bendigo, Victoria
    Engine ready for pull down:
    The minimal space i get to work with!!
    The little engine that WILL:
    Going in the Bin
    Jan 2010
    Bendigo, Victoria
    Anyway, have got onto ASR about a decent sump for the build. Looking into oiling system mods at the moment.
    Drag-comp sump: (*note the one pictured is for an RB30, but you get the idea)
    Engine has been completely stripped down. All I'm keeping is the block! Man the bin was heavy wheeling it to the kerb!!!
    Getting quotes to get a decent full-cage (weld-in) at the moment. Then I'll be looking at tubs, and then PAINT!!!!
    Jan 2010
    Bendigo, Victoria
    found the links i was looking for regarding the modified oiling system.
    ****Edit: these modifications are for an American buick and run a different system to ours. Gives me some ideas though
    How to build a front cover/oil pump - TurboBuicks.com
    and
    Motor Rebuild - TurboBuick.Com
    interesting reading
    Last edited by neet_wagon; 18-02-2010 at 01:25 PM. Reason: added some insight care of the all-mighty delcowizzid!! thanks
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    Quote Originally Posted by neet_wagon View Post
    Hahahaha, I couldn't stop laughing at that.
    I'm renovating my house and I reckon most of the shit I tore out of the front living room and bedroom went through my wheelie bin
    Jan 2010
    Bendigo, Victoria
    Yeah they must get sick of picking up my bin.
    First week after I got the VN the entire interior went in the bin.
    Week later all the random crap went in it.
    All I've got left is the shell, panels, block, kframe and diff (which im not keeping).
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    just so you know those links are for a totally different oil pump setup than what we run some of the block porting of oil is the same but the front cover and oil pump is not the same it hangs off the side of the cover ours is in the front of the cover with the balancer driving the pump
    Jan 2010
    Bendigo, Victoria
    ^^^ to tell you the truth i didn't even look at what set-up that was running!
    Thanks to Delco the correct oil/lubrication system modifications are located here: Another NZ Single turbo conversion
    Jan 2010
    Bendigo, Victoria
    Few more pics:
    Some genius hacked up the parcel shelf:
    More engine pics:
    The (hopefully) new heads:
    Sexy arse rocker covers:
    And the COME stroker kit:
    Its starting to look like a good-build, pity none of this is in my hands
    Aug 2004
    looking good, prob shouldnt have throw out the cam thrust plate though...
    not sure how youll go running gn heads on our motors either good luck with it all though
    в∞ѕтεכ √&
    Jul 2008
    NZ
    is that not the boost kit with H-beams in the pic obviously since they are I-beam rods heres the rods i was looking at $800
    Attached Thumbnails Attached Thumbnails My VN V6 dragcar 'project-101'-new-6-cyl.jpg   My VN V6 dragcar 'project-101'-new-6-cyl-b.jpg
    Jan 2010
    Bendigo, Victoria
    Cracker: Yeah we've been looking at the heads for awhile now, the US guys are adament that they'll fit, while most the guys over here say that they won't.
    But by looking at them and looking through the 'Project-VN' book from the late eighties a mate of mine has (friggin' awesome read btw!) it looks as though the only real change holden did was move the bore centreline by shifting the cylinder banks forward and aft.
    But in doing so they appear to have kept eveything in around about the same spot. (yes they moved the bore centreline, but the bore, water galleries and head studs appear to be in the same spot when in reference to thier original spacing.
    Delcowizzid: Its the COME kit, i got the pic off an email they sent me. You have me intrigued on these SPOOL rods though........ I saw them in another post of yours. What pistons will you be running?
    What about crankshaft? Someone said COME do standard stroke steel ones for around the $800 mark.
    - Though they haven't said anything about to me, and I've been corresponding a bit.
  15. #15
    в∞ѕтεכ √&
    Jul 2008
    NZ
    Buick Turbo V6 Engine Build Overview - GM High-Tech Performance Magazine bloody good oil mod in that article mate read about drilling the centre oil feeds
  16. #16
    Jan 2010
    Bendigo, Victoria
    You da man delco
    I see you've been and seen our mates oversea's........
    They don't reply much.
    Thanks for the article, will definately come in handy.
    This motor has been put on the back burner for a little while longer, as the wagon has decided to do the rear-main seal. May as well rebuild while its out.......
    Sucks balls, unless of course I can find a 5ltr for a grand or so, she'll be getting rebuilt.
    - 5ltr would be good though, gonna need something to tow the VN's trailer with, hmm...
    Who knows! Thanks for the info Delco, how's your beast travelling?
  17. #17
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah seen your thread over usa land thought ide hit it for replies LOL.still going strong so far hopefully go get some exhaust supplies today so i can get the 3" finished and crank up da BOOOOST some more
  18. #18
    Jan 2010
    Bendigo, Victoria
    How much boost you running atm?
    What sort of mainfolds did you use? Did you make your own log-style?
    I'm trying to make some tuned-length tubular ones, still in the design stages though (in my head at beer-o'clock) lol
  19. #19
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah just used a drivers side vr cast manifold on the drivers side and made a log for the passenger side works great easy cheap good place to start will make better ones later if i need too.boosting at 7 to 8psi had to burn my tune to a memcal needed the realtime ecu for another car havnt put it back in cause i need it again tomorrow so havnt tweaked the car in over a week tunes pretty good and reliable so just boosting round.dont want to crank the boost up till i have the 3" on the 2.5 has a little to much backpressure i think and dont want to pop the turbo seals out just for being impatient and cranking the boost
  20. #20
    Jan 2010
    Bendigo, Victoria
    Nice.
    Gotta love doing it on the cheap and easy!
    How's the cast one holding up? The passenger side ones tend to crack without boost, be interesting to see how it holds up.
  21. #21
    в∞ѕтεכ √&
    Jul 2008
    NZ
    its fine as you said the passenger ones crack lucky i dont use a passenger side one anywhere theres no weight on it either so not any real stress dont think it gets any hotter than without a turbo either havnt had it glowing yet
  22. #22
    Jan 2010
    Bendigo, Victoria
    Reckon. Lucky lol.
    loving the yet.........
    I was originally going to set-up a cheap turbo system for my old berlina using the seriesI manifolds,
    but i didn't like how the first and third faced each other.
    Never thought about the cast ones though...... even if it does eventually break, its not like it'll cost much to replace!!
  23. #23
    VQ V8 statesman
    Mar 2010
    bris
    sweet should go good
  1. My Project Vk
    By Dirbatua in forum VB - VC - VH - VK
    Last Post: 27-04-2010, 09:24 PM
  2. My Vr L67 Project
    By 6 shooter in forum VR - VS
    Last Post: 23-07-2009, 08:39 PM
  3. Project
    By Static89 in forum The LAN Lounge
    Last Post: 03-06-2009, 06:25 PM
  4. More project Q's
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-11-2006, 10:36 PM
  5. Old project car
    By Sphinx in forum General
    Last Post: 21-03-2006, 10:14 AM
