View Poll Results: What should i do next into 2008?
Voters
22. You may not vote on this poll
  • Finish off Vr Caprice Consol
    2 9.09%
  • Remove Vr Caprice Consol, Run B & M setup,no air con vents,custom elec window switches
    7 31.82%
  • Save For COME Twin Throttle Body Manifold
    12 54.55%
  • Cut & Polish,Full Detail,Boot Install
    1 4.55%
Page 1 of 23 1234511 ... LastLast
Results 1 to 25 of 563
Thread: Holden SS Commodore 355ci Stroker *RVN 355 *
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Exclamation Holden SS Commodore 355ci Stroker *RVN 355 *
    2005 Pictures of VN SS when purchased with Original Number Plate - WXY 476
    2006 Pictures Before 355 Stroker Rebuild with old Custom Number Plate - SUBDUE
    355 STROKER 2007
    • R SLOGAN PLATE : RVN 355
    • 1991 VN SS 355 Stroker
    • Power Pack Optioned
    • Level 2 dash with tacho
    • FE2 suspension
    • Genuine SS bodykit
    • Long Range Fuel Tank (80L)
    • Paint code: (Alpine White)
    • Side pinstriping with SS decals, pinstripe on front & rear bumpers
    • ‘SS’ and ‘Holden’ Decals on rear spoiler
    • Sports seats (series 2), grey with red piping and inserts
    • 19" RJR Torque 245 X 35 Chrome Wheels with 5mm universal spacers
    • Maxxis MA Z1 Directional Tyres
    • 10mm Red Walls - White Walls S.A
    • Bendix Advance Brake Pads, PBR Rotors
    • Tinted Windows 10 %
    • Pro Alarm System
    • 1.1KG (Kidde) Fire Extingusher mounted in the Boot
    • Replaced New Tension Bearings
    • Replaced New Regulator on Alternator
    • Replaced Washer Bottle Motor 29/2/08 SVM S.A
    • Calcium King 13 Plate 530 CCA Battery (Made by Delco)
    • Replaced Thermostat 130degree 21/3/08
    SUSPENSION / DRIVE TRAIN
    • KYB Excel G Front strut & Rear Shockers (short Stroke)
    • Nolathane Strut Tops Adjustable
    • Nolthane Strut Brace Adjustable
    • New Stub Assembly
    • New Engine Mounts
    • Nolathane Rear Lower Control Arm Bushes
    • Nolathane Front Lower Inner Control Arm Bushes
    • Nolathane ADJ Panhard Rod + Bushes
    • Nolathane FrontHeavy Duty Sway Bar Link Pin Kit
    • Nolathane Strut Bar too Chasis Bushes Front
    • New Uni Joints
    • New Wheel Bearings
    • New Tail Shaft
    • GMH Z bar
    • VL TURBO LSD 3.4.5 DIFF Gears
    INTERIOR
    • Issota (Made In Italy) Evoluzion Leather Steering Wheel (ADR APPROVED)
    • Blue LED's in Interior Light
    • VS Boot Carpet
    • VS Commodore Sun Visors
    • VR Caprice Cig Lighter
    • Grey Velour Roof Lining
    • Custom Vs Door Pods with VN SS Material Used.
    • VR Caprice Centre Consol (LEATHER)
    • RVN 355 Stainless Steel Din Cover Polished
    • Custom Embroadary on Centre Consol Lid - RVN 355
    • Charcoal Leather Red Piping Hand Brake
    • Replaced Windscreen - United Windscreens 2006
    • Autometer Guage Pod Mounted Passager Side
    • Vs Caprice Style Chrome Interior Door Handles
    PAINT + ACCESSORIES
    • Alpine White,VZ SS V8 Badge Fender, VE SS Badge's on Rear Doors Above Side Skirt
    • Re Sprayed Engine Bay 2pac Original Alpine White
    • Re Sprayed Rear Bumper,Bonnet Hingers Alpine White
    • Re Sprayed VP 5000 Letter Box Grill Alpine White
    • Re Sprayed Window Mould 2 Pack Black Enamel
    • Cut & Polished Paint Work
    • Detailed Seats Jan 08
    • Original VN SS Pin Decals Kit Replaced
    • Colour Coded Re Sprayed Alpine White Electric Mirrors
    • Phillips H4 Blue Vision 4000K Headlights Halogen Globes + Parkers
    • Engine & Various Engine Components Painted Alumininium "Silver POR 15"
    • Painted Alumininium "Silver POR 15" Engine Mounts
    • Resprayed Bonnet & detailed Inside 2007 - SVM
    • Aluminium Tig Welded (High Pressure) Expansion Over Flow Bottle - Bremen Welding & SVM
    • Polished Aluminium Tig Welded Washer Bottle - Bremen Welding & SVM 29/2/08
    • Polished Aluminium Tig Welded Fuse Cover with SS Engraving.
    • RVN 355 Engraved Billet Aluminum Master Cylinder Cover
    • RVN 355 Engraved Billet Aluminum Oil Cap
    • RVN 355 Engraved Billet Aluminum Power Steering Cap
    • SS Engraved Billet Aluminum Radiator Cap
    • SS Engraved Billet Aluminum Strut Caps
    • SS Engraved Billet Aluminum Washer Bottle Cap
    • Custom Made Stainless Steel Battery Cover
    • New Bonnet Cable 21/10/07
    • RJR Chrome Wheel Caps
    • 16cm Aeropro Stero Din Dize Blue 12V Neon Behind RVN 355 Custom Din Cover.
    • New VN SS Foglights + Lenses
    • 8-10mm Plastic Chromed Ignition Lead Holders - Sydney Speed Shop
    • Billet Trans and Engine Dip Sticks
    STEREO
    • Pioneer DEH-P1Y MP3 60Wx4
    • Pioneer 12" Sub + 2005 Pioneer Sub Cover
    • Pioneer 220w Bullet Splitz
    • Pioneer 5way 400w 6x9's in Rear Fiberglass Pods
    • Weconic 4ch Amp 800w 75W X 4 RMS
    • Sony 222w 2 Chanel Amp.
    HEADS
    • Machine & Clean Heads
    • Faced Valves
    • 3 Angle Grind
    • Profile Machine Valve Seats
    • K Liners
    • GMH head Kit
    • 2.02" Exhaust Inlet, 1.6" exhaust outlet
    • Flow benced 500+ hp
    EXHAUST
    • Pacemaker 5002 44mm Primary Headers Including HP Coating - AAA Exhausts S.A
    • Pacemaker 3" 5002 Exhaust Y piece (Brings headers into single 3" System)
    • 3" X Force Matt Black Mandrel bent Exhaust System
    • 3" Magnaflow High Flow Catalytic Convertor
    • 3" X Force High Flow Muffler
    • 3" Stainless Dump Pipe
    ENGINE & COMPONENTS
    • Torque Plate Honed,Acid Dipped, Crank Tested,Decked & Blue Printed C.O.M.E "Racing" Nodular Recipricating 355ci Billet Stroker
    • King Bearings & ARP Rod Bolts
    • Speed Pro Gasket Set
    • Crow Cams Pushrods
    • Speed Pro Flat Top Forged Pistons
    • 5 .7" I Beam C.O.M.E Conrods- Floating Conrods non press fit
    • l34 Stainless one piece Valves
    • Crane 284 Camshaft,Crane Anti Pump Lifters,Crane Valve Springs,Crane Retainers,Crane Valve Locks
    • MSD Ignition P2225 - External Performance Fuel Pump Rated @ 500hp
    • Holden VS V8 CAI,Holden VS V8 High Flow Air Box Top & Bottom, Rush High Performance Air Filter.
    • Yella Terra Platinum 1.6.5 Roller Rockers
    • JP Performance Oil Pump
    • Injectors Chemically,Flow Benched, Cleaned and Tested with new O Rings
    • Kilkenny Casting Timing Cover
    • Rollmaster Double Row Timing Chain
    • Powerbond Street Series Harmonic Balancer
    • GMB Water Pump
    • Haltech E6GMX Engine Managment System - Dyno Tuned on V power 98 Shell 172.6 Rwkw - Blackwood Dyno March 2008
    • PRB Master Cylinder
    • NGK Spark Plugs
    • Top Gun 8.8mm Red Performance Leads
    • New GMH Clutch Fan + Shroud
    • GMH Belt
    • Cleaned IAC Valve,Throttle Body & replaced TPS.
      1st service of Rebuild @ 192,500km 6th December 2007 - Paul Pavlou Motors,Valvoline 10w 40 Dura Blend,Wynns Coolant.
    TRANSMISSION
    Pro rebuilt TH 700 R4 Automatic lock up hydraulic controlled Transmission September / October 2007 - Steve@ Paul Pavlou Motors
    • CORVETTE SERVO PISTON
    • OVERSIZED HIGH PERFORMANS WIDE BAND
    • RAYBESTOS MODULE
    • FAIRBANKS STAGE 3 RACE APPLICATION T 700 4 SHIFT KIT
    • NEW CLUTCHES
    • STEEL T700 R4 - 4L60 E (.110)
    • NEW TRANSMISSION PAN
    • NEW TERRINGTON BEARINGS
    • NEW FULL GASKET SET
    • NEW VALVE BODY PLATE
    • T700 OVERHAUL KIT
    • MACHINED WASHER TRANS DRUM PUMP
    • NEW TRANS FILTER
    • NEW SEALS
    • 2500 STALL CONVERTOR
    • 0.55 " BOOST VALVE
    METAL POLISHING / PAINTED ENGINE PARTS
    • Polished 5000 Injection Rocker Covers
    • Polished VN 5000 Injection Engine Covers
    • Polished Receiver Dryer Air Conditoner
    • Polished Nolathane Strut Brace
    • Polished Custom Fuse Cover + Relay Cover
    • Polished 5000 Injection GMH Manifold
    • Ported & Polished V8 Throttle Body Inside + Outside
    • Polished PBR Master Cylinder
    • Polished Water Pump
    • Polished Timing Cover
    • Polished Trans Pipes
    • Polished GMH Ignition Module & Painted Red Hot Enamel Sourrond of Heat Sink.
    • Polished Alternator + Painting "GMH VZ Red Hot 2 Pac Enamel"
    • Chromed Alternator Bracket
    • Chromed Power Steering Pump & Bracket
    • Polished Thermostat Housing
    • Polished Dip Stick
    • Polished VN Fuel Rails
    • Polished Master Cylinder & Brackets
    • Polished Bolts / New Screws or Bolts For All Parts
    • Polished A/Con Pipe From Compressor To Receiver Dryer
    • New Strut Top Bolts
    • chromed alternator + pulley,crank and power steering pulley
    • New Vs Fender Bolts Polished
    • Headlight Clips Polished
    • Chromed VN SS Bonnet Hingers
    • Stainless Steel Hand Polished Gas Struts to suit vn ss
    • Chrome Bonnet Safety Catch Brand New
    • Chrome Bonnet Lock Pin & Spring
    • Painted Black Throttle Cable
    • Polished All Billet CNC Machined Custom Caps
    • Polished 4x Door Catches & Screws
    • Polished Boot Catch & Screws
    • Polished Aluminium Washer Bottle,Radiator Overflow,Fuse Covers
    MODS INTO 2008
    1. Custom Oil Filter cover
    2. Metal Chrome Outer Door Handles - Done but not installed as yet.
    3. Hide Engine Bay Wiring
    4. Chrome Strut Tower Bolts - Ordered
    5. Autometer ultra lite Oil Pressure Guage
    ENGINE BUILD COMPLETED PICS 2007
    Special Thanks To:
    • My Girlfriend,family and my Mates-Scott,Tim,Frank,Stephen
    • All The Boys in the Just Commodores S.A Scene
    • S & B Auto Electrical
    • Sprints Performance Kilkenny - Marcus
    • Exeter Crash
    • North East All Transport Upholstory
    • Paul Pavlou Motors
    • All Torqure Convertors
    • S.V.M Metal Polishing (KARL)
    • Tisonics
    • Motoquipe Westlakes
    • Jeff the plastic chromer
    • S.A White Walls
    • Mc Laren Engineering
    • AAA Exhaust
    • Blackwood Dyno Tune
    • Woodville Park Auto Repairs
    • West Croydon Auto Repairs
    • Growly Custom Machining
    • VNSS CLUB
    Cheers.
    * RVN 355 *
    raZel's Avatar
    raZel is offline The ride for life
    VY II Calais
    Feb 2005
    Subdue, can You tell me or out line how you have changed the HU to the space underneath? and how did you make the gauge display?
    ###n love the car ! clean, smooth, well maintained, nice mods....very nice indeed
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Cut out the plastic and used chequer plate and 2" holes for guages. Easy mate,my 1st attempt so maybe down the track something new and better will come along for guage wise,maybe pillar mounts or fiberglass. Ya can also have ur deck up the top and guages down but ur decision and try new ideas!
    Attached Thumbnails Attached Thumbnails Holden SS Commodore 355ci Stroker *RVN 355 *-jc-20-subdue-pic-21st-may-06.jpg
    Cheers.
    * RVN 355 *
    VNBOY Guest
    looks sweet.
    i think the color is 'alaskan white' not alpine, but hey white is white IMO and i love those body kits... makes the car look sharp.
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by VNBOY
    looks sweet.
    VN SS mate came with alpine white phonix red and atlas grey... calais executives etc... came with the alaskan white.
    Cheers.
    * RVN 355 *
    VN SS 5speed
    Jul 2005
    Default dyno read out
    shmick car mate, thats some nice rear wheel power your getting! was just wondering what type of headers you used? sometime soon im going to put a full system on my 304.
    was looking at the pacemaker 2 and 1/2 apparantely they are good??
    cat? isnt that an animal? no i dont want one in my exhaust system thankyou very much...
    my ride \/
    http://forums.justcommodores.com.au/...ighlight=seabs
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by seabs
    Im not 2 sure i have been told HSV Headers, but who knows they came with the car, sounds loud,goe's ok for a stocky engine with crap all mods so im happy with it and being a full time student really is hard. Pacemakers are good, consider other brands for obvious reason cost and what people recommend.
    Cheers.
    * RVN 355 *
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by nathans1987
    240nm peak is that correct i would have thought it was in the ~350nm.
    Im not sure its a fairly stock engine so i wasn't expected top numbers. Tho ill just focus on making it drive well and look good for now and engine work will happen one day when i progress thru my apprenticeship and get some more $
    Cheers.
    * RVN 355 *
    lowvt3.8 Guest
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Lightbulb
    Quote Originally Posted by lowvt3.8
    yo man nice car wheres some engine pics ?
    Engine Cover is Done here is the pics
    Attached Thumbnails Attached Thumbnails Holden SS Commodore 355ci Stroker *RVN 355 *-subdue-engine-pic-may-21st-2006.jpg
    Cheers.
    * RVN 355 *
    lowvt3.8 Guest
    hay man u should strip the paint off n polish ur engine covers shiny metal looks better then paint but thats me i did this 2 my vs ss n it looked trick
    roger rabbit Guest
    I wouldn't spend anymore money on looks until it had at least 200kw at the wheels.
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by roger rabbit
    I havent got thosands 2 to put into the engine just yet so i may do simple and easy stuff 1st. When i do the engine mate nothing less then supercharged or hot cam would be the best idea. Im under 25 so insurance is hard already so i think maybe later.
    Cheers.
    * RVN 355 *
  15. #15
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Question Engine Cover
    Thanks for the comment and sugestions
    Cheers.
    * RVN 355 *
  16. #16
    lowvt3.8 Guest
    yo man heres y i got the vt theres my nice shiny engine covers 2
    Attached Thumbnails Attached Thumbnails Holden SS Commodore 355ci Stroker *RVN 355 *-picture-006.jpg   Holden SS Commodore 355ci Stroker *RVN 355 *-picture.jpg   Holden SS Commodore 355ci Stroker *RVN 355 *-picture-007.jpg
  17. #17
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Thumbs up Black Vs Ss
    Luv the black vs ss there really nice, sorry 2 see the ss in the condition tho, what happened? , wanted a vs ss but $ tho, what would it cost me 2 do the polished engine cover and would a vt engine cover fit on?
    Cheers.
    * RVN 355 *
  18. #18
    lowvt3.8 Guest
    haha i was doin bout 90 kms on the highway old man pulls out in front of me then bang hah no more ss . done the engine covers myself they came up sweet it took a few day tho but it was worth it n 4 the vt covers im pretty sure they fit n do ur tappet covers as well im pretty sure u dont have 2 change the gasket either because there rubber i never got around 2 it because off the old man
  19. #19
    VS SS
    Jul 2005
    perth, southern suburbs
    that is a nice VN man...looks tuff and you obviously look after it well..I like the gauges you have put in the dash they look sweet
  20. #20
    CommodoreChick's Avatar
    CommodoreChick is offline Resident Female Bevan
    1985 VK
    Feb 2004
    Brisbane, QLD
    HeyHey
    Nice car, well looked after....
    If your looking for suggestions of new things to do...
    (I could be biased cos im a spray painters GF lol) But i reckon a new paint job, the paint you've got looks in great nick, but nothing makes a car stand out more than an awesome paint job (eg look at my ride... before and after pics)
    But if your more interested in keeping it original SS colour I compleltely understand.
    sometimes completely changing colours can be a pain in the ass, we did it for mien and it involves painting in the door jams, boot etc. Another option is getting a pearl overlay for your white, you can get some pretty awesome looking stuff theese days
    ANYWAY all just something to think about
    Tara
    Say No To Ricers
  21. #21
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by CommodoreChick
    HeyHey
    Tara
    Thanks i really like the apline white ss, not alot around more off the altas grey ones so i wanna keep the original scheme. Tho Engine Mods + Engine 5000i Cover Polishing is really in the top 5 things 2 do next
    Cheers.
    * RVN 355 *
  22. #22
    ford
    May 2005
    in a ford
    great ride keep up the good work
  23. #23
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Talking Thanks For Comments
    Thanks for the comment, have some pics on the site soon with my engine covers done when i get time to upload em
    Cheers.
    * RVN 355 *
  24. #24
    SUSPECT's Avatar
    SUSPECT is offline Banned
    SUZUKI GSX-R 1000 k8
    Aug 2005
    adelaide, southern suburbs
  25. #25
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by fizz_vk
    car looks heaps sick uleh
    cheers bro like ur filly sik vk is wild 2 man - luv da plate
    Cheers.
    * RVN 355 *
LinkBacks (?)
  1. wtd: holden 5.7 stroker
    By VROCIOUS in forum Swap / Wanted to Buy / Trade
    Last Post: 12-12-2007, 02:40 AM
  2. Stall Convertors - What to do with Stroker 355ci
    By RVN 355 in forum V8 Development and Modification
    Last Post: 17-02-2007, 10:26 PM
  3. holden 308 v8 motor worked to a 332 stroker
    By ma77es in forum Parts And Other Items For Sale
    Last Post: 10-11-2006, 12:45 PM
  4. 355ci stroker chips
    By onsta004 in forum V8 Development and Modification
    Last Post: 26-04-2006, 05:21 PM
  5. Holden Calais VS vs Holden Commodore vn
    By holdn in forum General
    Last Post: 08-02-2006, 10:08 PM
