Results 1 to 18 of 18
Thread: VN Calais 355
    VN Calais 355
    Sep 2011
    NSW
    Default Daily Driver - VN Calais 355
    Bought the car from Victoria 3 months ago(May), picked it up at 11pm, drove straight back to sydney, back at work 7.30am next morning. Very tired during the day...
    Spent a bit of coin getting this car roadworthy and back to a good standard. It's now registered and running a lot better than when I first got it. Bloke I bought it off, said that its making 187rwkw.
    I doubt that though seeing the condition it was in. After a proper tune, fuel pump upgrade and the new intake manifold, hopefully it should be making between 220-230rwkw.
    Fuel economy at the moment is shit, only getting about 240kms to a tank.
    Feel free to leave any comments. Always good to get other people's thoughts and ideas.
    Car: 1989 VN Calais Series 1
    Engine: 304i stroked to 355i, 10.5:1 compression courtesy of some Hypertek pistons, bearings and rings,
    304 Crane hid cam, bigger injectors, roller rockers, shaved head
    Odometer: Dash - 299700, Motor - 55,000
    Exhaust: Stock headers, standard cat, 2.5" cat-back piping.
    Gearbox: 5 speed manual
    Colour: Two-tone champagne gold and silver
    Exterior: Standard
    Interior: Standard
    Diff: Non LSD 3.08
    Suspension: Front - Monroe GT Gas struts, Lovell springs
    Rear - Pedders Sports Ryders, Pedders Touring Springs
    Brakes: Front - Slotted rotors(standard v8 size), Bendix GCT pads
    Rear - DBA slotted rotors, Bendix GCT pads.
    Wheels: 16x7 VN SV5000
    Tyres: Front - Bridgestone Adrenalin RE002 225/50/16
    Rear - Bridgestone Adrenalin RE001 225/50/16
    Bad Points:
    Plastic gearstick surround broken
    Needs new rubber boot seal
    Instrument panel surround missing trip computer button
    Needs dyno tune
    Exhaust manifold leak
    Rust under LHR door rubber
    Carpet in boot is needs re-laying
    Daggy interior
    Tie rod ends
    Inner lower control arm bushes(urethane)
    Castor rod bushes
    2 x rear tyres
    Needs a better exhaust system
    Rocker cover gaskets
    What I've Done:
    All 4 power window regulators
    All 4 central locking actuators
    New alarm + immobiliser
    Replaced ignition barrel(had to start it with a screwdriver when I first bought it)
    Rear shocks and springs(Pedders Sports Ryder shocks, Pedders Touring Spring)
    LHR & LHF Door Seal
    Replaced both tail light looms
    Reversing lights re-wired
    Horn re-wired
    Replaced pod filter with stock airbox w/ high-flow lid
    Spark plugs, engine oil, oil filter, K&N air filter, fuel filter, new radiator cap, brake fluid, 9mm Eagle leads
    New rear tyres
    Slotted front rotors + new pads
    Slotted rear rotors + new pads
    New master cylinder
    New exhaust piping from cat-back
    Replaced globes behind the instrument panel
    Adjusted the handbrake
    SAAS steering wheel
    Bought engine covers
    HSV Hi-flow airbox lid
    RH hi-beam globe
    VN SV5000 wheels 16x7 w/ RE002 Adrenalin 225/50/16 x4
    Replaced tired diff with a lower km diff from VN SS, spray painted it chassis black
    Upper and lower trailing arm heavy duty rubber bushes, urethane swaybar link-pin & D-bushes
    Replaced tailshaft centre-bearing
    80ltr long range fuel tank with a single in-tank Wahlbro 255l/hr hi-flow pump
    Fuel pump relay
    Second hand R/H side bracket for rear bumper bar
    Replaced front struts(Monroe GT Gas)
    New strut boots and bump stops
    Nolathane Adjustable strut tops
    New front upper spring seats
    New lower ball joints
    Procomp Output Coil
    Second hand L/F body bracket for the front bumper
    DBA Slotted Rear rotors with Bendix GCT pads
    Alpine Head unit, Kicker front speakers(mounted in VR/VS factory door pods), Kicker rear speakers, Kicker 12"sub and Kicker amps
    Future Plans:
    C.O.M.E. Racing Intake Twin Throttle Manifold
    Braided brake lines (F + R)
    VN/VP SS bodykit and spoiler(?)
    VY/VZ SS complete interior
    1 3/4 extractors, twin hi-flow cats, 3" mandrel-bent to a twin dump-pipe tip
    Air-Fuel ratio gauge
    Bigger brake set-up (343mm front rotors, 315mm rear rotors)
    VE Thunder Charcoal Grey respray
    VN SS letterbox grill
    Castor rod bushes(urethane)
    Oil cooler
    Gearbox cooler
    Low 12sec 1/4 mile
    Pictures:
    VN Calais 355
    Sep 2011
    NSW
    Bought a complete set yesterday for $150. Fairly good nick, soon to go on once I've put new 225/50/16 Adrenalins on them.
    vn ss
    Sep 2011
    sydney
    She looks pretty straight, some 3.9's and come manifold and its happy days.
    SS kit will look cool. you may aswell paint it atlas grey if your putting the ss kit on.
    VN Calais 355
    Sep 2011
    NSW
    Yeah, grey seems to fit commodores well.
    Spoke to the guys at Silverwater Auto Services, pretty happy with what they had to say. I'll be taking the calais down there soon so they can put on the new manifold, upgrade the fuel pump, put a new set of headers and a hi-flow cat on and give it a good dyno tune. Lad I spoke to, reckons I'll probably get around 240-250rwkw mark, all going well.
    vn ss
    Sep 2011
    sydney
    Quote Originally Posted by thewhisper17 View Post
    Did you get a qoute for the tune mate???
    i woundn't worry about hiflow cat, your standard will be just fine.
    VN Calais 355
    Sep 2011
    NSW
    Excluding headers and the cat, looking around the $1400 to $2000, depending on if they find any problems.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Have you changed the engine covers around? they are on backwards
    355 on a single pegger - LSD will help get the power down.
    and 3 Dangerous non ABS VN's
    VN Calais 355
    Sep 2011
    NSW
    I don't see how they're on backwards. :S
    Yeah, bloody oath. I'll be getting a 3.45 LSD soon. Just gotta source a good one.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    The gap on the top covers are suppose to be at the back not the front. so you just swap then over
    ~ VN POWER ~ Click the scales
    VN Calais 355
    Sep 2011
    NSW
    Picked up a disc to disc 3.08 LSD from a VN SS off ebay. Should be better than the single pegger I have now...
    Changed the engine covers. Looks better. :P
    Sprayed the calipers today.
    VN Calais 355
    Sep 2011
    NSW
    Pulled the rotors and calipers off the diff that I bought. Gonna rebuild the calipers, new slotted rotors, new pads, new hubs, brake shoes, handbrake cable(s) and re-spray it, put new bushes in when I bolt it in under the car. Will be much better than the single legger I have now...
    vn ss
    Sep 2011
    sydney
    VN Calais 355
    Sep 2011
    NSW
    Quote Originally Posted by MADSS View Post
    I have 3.45 diff gears if your interested.
    I am interested. How much and what car are they from?
    vn ss
    Sep 2011
    sydney
    VL turbo and chasing $130.
  15. #15
    VN Calais 355
    Sep 2011
    NSW
    Over the past 4 days, I've taken out the old diff, and started to prep everything for the new diff. New upper and lower trailing bushes, urethane swaybar bushes and urethane link-pin bushes. Also painted all the trailing arms, the new diff, rotor hubs, swaybar, link-pins and panhard rod 'chassis black'. I'll post some photos tomorrow of the work done so far.
    Had a closer look at the diff center, and it turns out it isn't an LSD. Feeling pretty ripped off. My own fault though, should have checked before handing over the money. At least
    this diff is in much better condition. Thinking about rebuilding the old diff; new axles, new LSD center, 3.45 gears, etc, eventually.
  16. #16
    VN Calais 355
    Sep 2011
    NSW
    Finally put a long range tank in and a hi-flow fuel pump, made a big difference. Will post pictures later on today.
    The long range tank before it went in.
    And some recent pictures of the car.
  17. #17
    VN SS
    Dec 2011
    cranebrook
    VN SS
    Dec 2011
    cranebrook
    Any updates??
  1. [VIC] SWAP - SSL IRS springs for VT Calais door trims/Calais suede dash kit
    By sxc_sound in forum Swap / Wanted to Buy / Trade
    Last Post: 13-02-2011, 11:05 PM
  2. Replies: 5
    Last Post: 07-02-2011, 11:01 PM
  3. [SA] [WTB] VX Calais Chrome Strip and possibly VX calais aftermarket/genuine monaro lights
    By Robertoe in forum Swap / Wanted to Buy / Trade
    Last Post: 31-10-2010, 04:29 PM
  4. [SA] WTB VL Calais Stock Radio/Casette, Vl Calais Badges
    By reids22 in forum Swap / Wanted to Buy / Trade
    Last Post: 18-08-2010, 05:30 PM
  5. [SA] vx calais altezza monaro lights and vt/vx calais doors
    By callum_88 in forum Parts And Other Items For Sale
    Last Post: 24-04-2009, 01:33 PM
