'92 HSV VP GTS - Sokoza
Sokoza
Beep Beep
QLD
'92 VP GTS
1992 HSV VP GTS
A restoration project featuring HSV’s resurrection of the GTS badge, the VP GTS. Born in September of ’92, they started life as a Berlina before being carted off to HSV for the royal treatment. Descending from the VN Group A SS it has some similar features, such as a modified body kit, larger 330mm brakes and the illusive Black Engine block with D port heads and 4-bolt mains which produced 200kw with a regular manifold. The interior was layered with a blue velour and had 3 different options, standard, devonish or devonish with leather bolsters. The GTS was limited to 130 units and came in Maranello Red, Anthracite Grey or Alaskan White.
Underbody Works List - 1992 HSV VP GTS
-New slotted rotors all round, new pads.
-Re-sealed brake calipers
-Braided brake lines
-Billstein shock absorbers with King springs (Supers front, Ultras rear)
-Differential swap with 3.9 ratio gears, custom reluctor rings for ABS
-Full SuperPro bush kits all round with link pin kit
-Whiteline adjustable sway bars
-Polished brake lines
-Stoneguard underbody spray
-New bearings, tie rod ends and ball joints
-Adjustable KMAC strut tops
-Spray painted parts inc:
Fuel tank, straps, tailshaft, diff, exhaust, front struts, springs, shockies, diff mount, rotors, brake calipers.
To follow the build and see all the pictures check this blog:
Whips
stockies
Bannana
S/E Suburbs
G6E Turbo
You sonabitch.
Have always wanted one of these.
More Pics!
Sokoza
Beep Beep
QLD
'92 VP GTS
You sonabitch.
More Pics!
Hey Stockies, you've probably already seen the pics I just posted bove. All of the new stuff is on my tumblr blog linked above.
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
I feel a disturbance in the force!
somefool
Adelaide, SA
www.facebook.com
1991 VN 'S', 1997 Ford Laser 1.6
god damn thats clean!
This is the first and last time I will say this in regards to a commodore: Those angel eyes look awesome. And menacing.
Rusty
٩(-̮̮̃•̃)۶
Queensland
Vt with VU/VZ bits
Nice and tidy! How many km??
Hoska91
Formerly 75HJPREM
Getz Lyfe & E34 Project
Any info on how you did the angel eyes ? or are they shopped ?
Sokoza
Beep Beep
QLD
'92 VP GTS
Thanks :) Yeah I came across a tutorial on how to make you own so I gave it a crack. Thinking about switching out the blue for a white.
192,000kms.
somefool
Adelaide, SA
www.facebook.com
White would probably be better and help give a sharper look. LED white that is, not halogen-white. The blue looks so cool in that dark photo though. Kind of reminds me of Transformers for some reason
