B]Model: [/B]VN
Colour: Imperial Blue
Bodykit: VT Clubsport with no rear wing
Engine Type: 3.91
Engine Mods: -Full Engine Blueprint and Way to much to list here , Makes just under 180 rwkws N/A and 330 with Nitrous , Twin TB Manifold etc .
Click here to see full specs :
http://www.cardomain.com/ride/297016/2
Power: 178.5 at the Rears N/A and 328 on Nitrou so far
Exhaust: Full Diffilipo Extractors, Twin Cats and Twin 2.5" Cat Back into 3" over the diff.
Gearbox: Rebuild 5 speed,Custom GM Motorsport Ripshift Quickshifter ,Hydroulic Clutch with and Extreme 3200lbs Cushion button clutch.
Diff: 4 pinnion LSD, 3.91 gears, Brand New
Brakes: Twin Piston HSV Fronts wif slotted/Crossdrilled rotors and Racebrake RB 74 pads.
Suspension:Lowered professionaly by Centreline Suspension using the Works Kit KYB Shocks and Shellby Springs and Swaybars etc, Nolathane bushes
Wheels/Tyres: VX Calais Internationals 17" Bridgestone tyres
Interior: retrim seats , VX Clubsport Style , All Cobalt Autometer Gauges, Tacho , Momo Wheel etc
Other Mods: Hidden Wet Fogger Nitrous System , Sony Explod H/U 2 amps , Sub box, Front 6.5" splits, Rear 6x9 3 ways.
90 ltr Drop Tank, 3 way Sunroof .
Cost: Over $30'000 , Motor alone was $16'500 Motor, $1900 GearBox Rebuild, $1200 Diff, $1500 Interior retrim and heaps more .
hey m8, luv ya VN, looks good wat u gonna do nxt to it?
Check Out My Ride Here: 91 VN Calais[/CENTER]
ummm that like the best vn EVER...
Engine Bay Pics :
can you explain why you only lost 2kw from the flywheel to the rears? whereabouts in vic are you i wanna see you nos setup?
Decided to delete it, my mother told me to never say anything unless it is nice.
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
- Theodor Seuss Geisel
when i saw the thread title i was expecting some p plater with a completely stock vn, but thats a nice car.
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
180rwkw.... I find something iffy about that...........
Prove it!
MaT
EDIT: Just saw your dyno sheet on ur cardomain site.........
With 16,500 you could put a v8 into the 9sec mark....................
Originally Posted by garth
I would like to know the setup for getting 150 RWKW out of a wet nos systemOriginally Posted by HoZy
ROFL
Sneezing mate, he's got a cold.....
engine size??? 3.91?? dude u put in a stroker kit and not mention it?
Thanks to all those who praised the car .
And for those who called me stupid for spending so much on a V6 , I don't care what you say .
I've always liked the VN V6s ever since they were released in 88 .
I wanted to do something different, Also the car idles very well and is great on petrol too,
This is my daily driver now , I do around 600ks a week .
Its very easy to put 150 kws on nitrous with a wet setup.
Its the fuel side of things that tricky ,
I'm running a surge tank with a 910 pump and adjustable fuel reg .
Fuel pressure is 58 psi .
It squirts Nitrous and Fuel at the same time into the manifold .
This motor was built to withstand a 200+ Hp shot of nitrous , Hence the price .
Alot of thought and money went into the bottom end.
The crank is 3.51 stroke with an overbore of 30thou .
Its a crankshaft rebuilders( Melb) Offsett Gring crank .
I didn't want to use the Bradley Crank because I have seen them fail under boost and another fail in a speedway car at high revs.
And they don't like to be reved over 7000rpm .
Do you exceed 7,000rpm?
did you forget my question mate? cos i think your full o crap saying you only loose 2kw from flywheel to the rearsOriginally Posted by Charg'd
where does it say engine power i only see
andMakes just under 180 rwkws
yeah it doesnt say flywheel power anywhere in the thread Charg'd
nice car mate looks awesome. top points for being different and at the end of the day those who think you are full of crap **** em its ur car u put the hard hards and dollars into it so u obviously wanted it done so who gives a shit what anyone else thinks. well done mate keep it up.
with plates like that you have to have a fast car :P
those sort of mods are well out of my price range, but hey i aint running nos in my car so i dont have to
good luck with it all
I never stated flywheel Kws , I don't know them and its hard to tell .
Don't go calling me names just because I did something different .
The power is acurate , Not bodgied up with correction factors on the dyno like most people do .
I have dyno sheets that range from 178 -200 rwkws done on different dynos , But I only state the lowest reading of 178 to be far .
I've built 5 worked V6 engines before this motor power ranging from 120 kws to 145 kws , The other engines were nowhere near as tuff as this one now .
If you doubt the power give Steve at S&S Racing a Call and ask him yourself . 03 9310 7842 .
Engine Bay Pics:
