Results 1 to 8 of 8
Thread: My vn v6 rebuilt engine gearbox and spooled
    Aug 2004
    Default Vn v6 worked engine gearbox and spooled going turbo :)
    this is my vn was resprayed at tafe few years ago its a 1990 series one with a series two engine that has been bored and honed 40thou, ACL race series pistons and chrome molly rings, standard con rods, crack tested, check for bend and twist, fitted with ARP bolts, resized, pistons and con rod blanced, skimmed heads, 3 angle valve seats, k-line guides, new stem seals, slight port work, stock manifold with 65mm throttle body and ported elbow, wade 992a cam, single row roll master timing chain, ACL big end and main bearings, new seals through out, new brass which plugs, bosch super 4 spark plugs topgun leads. Standard series one headers into new stock red back cat into super cat mandrel bent 2.5” system.
    it also has a rebuild turbo 700R with corvette 1-2 servo, .500 boost valve, modded seperator plate, 7, 3-4 fricitons, wider band, solid accumualtors, new reaction shell. with a standard stall, it also has a mini spool diff.
    vp front breaks dba rotors on the front king springs in the rear.
    full vp vactioner interier, seats door trims etc, 2" water temp gauge and 2" oil pressure gauge and 3.5" tacho all spec, vr steering wheel, tacho dash, letter box grill, smoothed and repainted engine bay new radiator on 15" stockies most of the time. probaley other things iv forgott but yeah... did everything my self apart from build the auto and paint the car.
    Okay bit of an update blew the auto about 3 months ago had it rebuilt again with a beast reaction shell and steal pistons cracked 3-4th piston, and burnt the 3-4 clutch a little, any so now its good for some power.
    also got my self set of genie headers, which will be making way for a t3/t4 turbo which i built from a vl t3 and an aireaseach t04,
    new bearings thrust washer/bearing, seals and piston rings,
    brought some log stlye steam pipe manifolds from another forum member and also got a turbo smart vee port and boost controller, meter of braided line, and an old school turbo timer, also got a set of blue top injecotors.
    Next thing is dump pipe, cooler, fuel pressure regulator, chip, and a cooler piping.
    aiming for 200rwkw at 6psi hopefully.
    Attached Thumbnails Attached Thumbnails My vn v6 rebuilt engine gearbox and spooled-ddd.jpg
    Aug 2004
    car
    Jul 2006
    greensy, melb
    good work mate she is a very neat car
    "A life lived in fear is a life half lived"
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    wicked man, very nice!
    it's not overdone! very nice neat looking car from the outside!
    I think you need some hubcaps, headers, custom tune to cater for the cam!
    then a dyno and let us know how you go!
    oh, and i like the bay! i can appreciate the work gone into it
    Aug 2004
    thanks for all the comments guys yeah the bay took for ever prob 20 hours work and its not very good really, it looks better then it is in photos.
    i also did that my self.
    yeah i dont have any money for a tune or headers though lol
    wes_v8's Avatar
    wes_v8 is offline WES_VN
    04 Vz Sv6 6 speed
    Jun 2005
    Maitland near Newcaslte N.S.W
    Aug 2004
    Pictures
    The plan is to run 6psi, then up it too 10psi and swap the cam to a custom crow turbo cam.
    Attached Thumbnails Attached Thumbnails My vn v6 rebuilt engine gearbox and spooled-enigne-bay-dumpy-test-fit.jpg   My vn v6 rebuilt engine gearbox and spooled-gear-bov-boost-contorler.jpg   My vn v6 rebuilt engine gearbox and spooled-test-fit-one.jpg
  1. F/s: Rb30et Rebuilt Engine (vl Turbo)
    By GMH-JC in forum Parts And Other Items For Sale
    Last Post: 11-08-2008, 06:52 PM
  2. Mini-spooled my VP ute
    By hispeedvp in forum General
    Last Post: 15-10-2007, 04:43 PM
  3. Anyone know how much to rebuilt vn v8 manual gearbox!
    By low_vn_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2007, 11:29 PM
  4. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  5. Engine has been rebuilt
    By v6vn/vpwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2006, 08:38 PM
