Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > My Ride > VN - VP - VG - VQ
VN - VP - VG - VQ A fan of the squared arches? Why not post your ride.
Reply
LinkBack Thread Tools Display Modes
  #301
Old 24-03-2008, 09:22 PM
Peanuts Inc.'s Avatar
Ride: 355 VG :)
Trade Rating: (0)
Peanuts Inc. Caprice
take it to a workshop with an oscilloscope and do the test i left on a post earlier
if it pulses erratically then replace it its how i found my faulty sensor
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
  #302
Old 24-03-2008, 09:24 PM
Ride: 355 VG :)
Trade Rating: (0)
Quote:
Originally Posted by Peanuts Inc. View Post
there is a test for the hall affect sensor. you wire the dizzy power and earth up to a battery, hook the signal wire up to an oscilloscope, use half inch hose and slide it over the bottom of the dizzy shaft after the gear is removed, use a cordless drill with a 13mm drill bit and slide it up into the bottom of the half inch hose, make it spin and check for the square pattern on the oscilloscope screen
if its not reading correct there will be a flat line momentarily in the square pattern on the screen
i dunno if its the correct way but its the easiest way i found when i was checking mine cos i had an intermittent misfire with my old dizzy
sounds dodgy but it works
thats the way i did it
  #303
Old 25-03-2008, 07:30 AM
Reaper's Avatar
Tells it like it is.
Ride: VE SS-V, VP SS
Reaper GrangeReaper GrangeReaper Grange
Quote:
Originally Posted by Mack View Post
Hah, not this car, stock is the aim of the game. Nice try though.
Not as silly as it sounds. By now the original cam may be showing signs of wear.
Reaper
  #304
Old 25-03-2008, 09:28 PM
Mack's Avatar
Cant Pretend
Ride: '92 HSV VP GTS
Mack Monaro
Quote:
Reaper
Yeah, I thought of that aspect too, replacing it with another stock variation cam. Its known that 5 liters chew cam lobes. From what ive seen the lobes look ok. Once I get the dizzy back in Ill crank it by hand and check the cam all the way around. I dont have the funds for a cam and lifters now anyway. Maybe next time.
__________________
Build 018/130
14.6 Sec Sex Machine
If its got WHEELS or TITS it'll give you the Sheets!
Ban LOW Performance Drivers, NOT High Performance Cars.
  #305
Old 26-03-2008, 01:38 PM
Mack's Avatar
Cant Pretend
Mack Monaro
Distributor/Hall effect sensor tested today, its all clear....So I went and got my ign module and they are testing it as we speak. I could have sworn that it was the dizzy.
__________________
Build 018/130
  #306
Old 26-03-2008, 07:37 PM
Mack's Avatar
Cant Pretend
Mack Monaro
Ignition Module, tested and found cracked solder and should fix the problem. O well, now the car should go better with the mani getting a good clean and new parts.
__________________
Build 018/130
  #307
Old 27-03-2008, 12:31 PM
Mack's Avatar
Cant Pretend
Mack Monaro
Bought more goodies today, got coolant and more vacumme hoses and all sorts of stuff. Sent my memcal away again to Foam-King for a upgrade, thanks allot champion. Ive got a new washer bottle on order from holden and some other stuff coming in tmr. I also went down to a smash repairer and put my rocker and injector covers in to be painted! $150 cash for 4 covers isnt too bad, and they will be done by tmr arvo! Talk about service! So this weekend she should be up and running, then I will get my tune back next week and awwwayyy she goessssss.
__________________
Build 018/130
  #308
Old 28-03-2008, 04:36 PM
Mack's Avatar
Cant Pretend
Mack Monaro
Rocker & Injector covers are back....in black! Looking nice and sexy. Got the last of my goodies today including a brand new washer bottle, vacumme hoses and some paint stripper. Time to get stripping.
__________________
Build 018/130
  #309
Old 28-03-2008, 04:49 PM
greenfoam's Avatar
Ride: VP Executive R-spec
Trade Rating: (0)
greenfoam Grangegreenfoam Grangegreenfoam Grange
mmm what are you using paint stripper on Mack? (that means warning)
__________________
VP executive-R 0-60mph 5.36 11/10/07, PB ET 9.101 1/8th mile at Southcoast raceway 30-11-2007
VN Lexcen GL 0-60mph 6.95. 1/4 mile 15.37 @ 91 mph: calculated rwkw 114
VH SL/E 202 Auto 0-60mph 13.5
5-12-08 Friday night street drags can 8.99/13.99 be done on a 2.5 inch exhaust? that is the question that will be answered
Download the flyer for the next street legal drags
http://www.southcoastraceway.com/ima...dec-5-2008.pdf
My VP, going fast on the cheap
  #310
Old 28-03-2008, 04:52 PM
Mack's Avatar
Cant Pretend
Mack Monaro
Quote:
Intake Manifold.
__________________
Build 018/130
  #311
Old 28-03-2008, 04:55 PM
Reaper's Avatar
Didn't think it was painted???
Reaper
__________________
  #312
Old 28-03-2008, 04:57 PM
Mack's Avatar
Cant Pretend
Mack Monaro
Reaper
Foamie told me it is.
__________________
Build 018/130
  #313
Old 28-03-2008, 05:01 PM
