| VN - VP - VG - VQ A fan of the squared arches? Why not post your ride. |
26-06-2008, 08:14 PM
Tells it like it is.
Ride: VE SS-V, VP SS
Quote:
Originally Posted by Mack
Idles ok, yeah its rich all the way through. No code for oxy, but since its been running rich for ages I BET the oxy sensor is rooted too man. Too bad I got no money for a new one.
If it is too rich it probably won't idle very well. My VP was rich at idle hunted rpm at even 14.1:1. I set it at 14.5 and it is rock solid now. I think I'd be doing a bit of investigation before spending a heap of money. Unbolt your 02 and have a visual inspection of it for a start. That bit is free. Check to make sure all your temperature sensors (back to the ECU) are functioning correctly (use a multi-meter). Make sure the ecu doesn't think the car is stone cold and is tipping a heap of fuel in there when it isn't necessary.
Reaper
26-06-2008, 08:22 PM
Cant Pretend
Ride: '92 HSV VP GTS
Quote:
Reaper
I have a delayed primary pattern on ignition system. I will try and get the oxy out, im sure it will be black, just like my 8 spark plugs. This saturday im trying a friends ECU out, if that fixes it, thats what ill be getting. Ill also but a new ign module and maybe a oxy sensor.
__________________
Build 018/130 14.6 Sec Sex Machine If its got WHEELS or TITS it'll give you the Sheets! Ban LOW Performance Drivers, NOT High Performance Cars.
26-06-2008, 09:58 PM
Banned
Ride: 304 Calais
The 02 would play a part in it running rich but i doubt its the main cause, i thought you had a new ign module and coil??
Lots of random guesses to fix the problem with no definate answer from any of the mechanics youve visited, if you keep splashing cash towards it itll eventually be fixed..
tell us exactly what you have and havent replaced.
26-06-2008, 10:08 PM
Donating Member
Ride: VN Calais Project - 88 VN Wagon daily
Reaper how are you measuring your a/f ratio with a wbo2 sensor?
27-06-2008, 01:44 AM
Ride: VP Executive R-spec
Just remember 14.7 is not correct afr's for idling well on most cars, maybe reapers but 13.5:1 is more like it for most cars, even less with a good cam. To make it stop hunting the VE map needs to be more constant in the idle range, it's not much to do the the ratio itself but the variation in ratios as it changes vacuum when idling
__________________
VP executive-R 0-60mph 5.36 11/10/07, PB ET 9.101 1/8th mile at Southcoast raceway 30-11-2007
VN Lexcen GL 0-60mph 6.95. 1/4 mile 15.37 @ 91 mph: calculated rwkw 114
VH SL/E 202 Auto 0-60mph 13.5
5-12-08 Friday night street drags can 8.99/13.99 be done on a 2.5 inch exhaust? that is the question that will be answered
Download the flyer for the next street legal drags
http://www.southcoastraceway.com/ima...dec-5-2008.pdf
My VP, going fast on the cheap
27-06-2008, 06:36 AM
Quote:
Yes. Check out my thread at the bottom of this post for details (last page)
Quote:
You need to keep in mind this motor is quite old and the cam (along with everything else) will be starting to show it's age.
He has a new coil and checked the ignition module. You are correct about the 02 playing a part but may not be the main cause however he has spent a lot of money shooting in the dark and perhaps it is time to get a little more methodical in diagnosing the problem. I would be checking the temp sensors haven't failed giving results similar to the $19 bs resister thing on ebay.
02 is an easy check with an aldl cable or multi meter as are most of the sensors.
Reaper
27-06-2008, 07:38 AM
Cant Pretend
The reason its so hard to diagnose is because of the mutiple problems all contributing to one main issue. The o2 sensor would have logged a code or shown on the diagnostic, it hasnt as yet, but im willing to bet that its going to be the ecu. Like I said, im going to swap ECU's this weekend and see if that solves the issue. If its not the ECU then its the Hall effect Sensor, which was TESTED by an auto electrician to be FINE. I worked through the most logical solutions int he first place and when I was lost I went looking for professional help, the first mob didnt help me, so yes a waste of money, how was I supposed to know they coudnt find anything? The Second mob were good, they found that the fuel pressure regulator valve was rooted and loosing residual flow. We/they thought that would have fixed the issue, but no, they also found when putting their finger on the Ign mdle transistor and putting another finger on a ground it would tingle/jolt you, signs that it was dieing. They tryed a new ign mdle and it didnt fix the starting/flooding issue. Temp and O2 would log a code if you ask me, and when they ran it on the diagnostic they found a delayed primary ignition signal. I also have posted numerous times in numberous threads what I have and havnt replaced etc, I dont feel the need to keep repeating myself.
Its not an easy diagnosis when multiple items are failing all at once.
__________________
27-06-2008, 12:54 PM
For external use only
Ride: 5sp VQ Statesman 5.0
I REALLY hope the ECU fixes this problem for you. You've screwed around more than long enough trying to get this thing straight  It's not fair, you look after it so well!
27-06-2008, 09:28 PM
Cant Pretend
ECU was the issue the whole time! Starts every time with a differnt ECU, YAY. The ecu also logged a MAT sensor code, so ima get a new MAT and ECU and IGN MDLE and OXY sensor and be done with it.
__________________
28-06-2008, 12:46 AM
Donating Member
Ride: VT Commodore Exec/5L VP Calais
Yay bout time mack hahaha well at least now u shouldnt have any problems with nething 4 a while now haha uve replaced just about everything new. remember ignition module from repco get a reco 1 4 $138  u should also b able 2 get an O2 sensor same place 4 $45
28-06-2008, 10:38 AM
crappy ol' VN driver
Ride: VN3.8 5spd/VSII3.8/VH5.0
good news mack. not so good for the wallet but alteast the beast lives. sounds like time for a cruise
__________________
Body by Holden, Soul by Brock the Legend will live forever
quote of the week
Quote:
Originally Posted by VT-565
why don't you want to go forshed induckshun?
28-06-2008, 03:16 PM
Finally. Great to see you have it sorted.
Reaper
