Page 34 of 55 FirstFirst ... 2430313233343536373844 ... LastLast
Results 826 to 850 of 1357
Like Tree1Likes
Thread: Morton's white VQ Statesman
  1. #826
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Quote Originally Posted by vn calais manual View Post
    haha thats not a bad effort on the exhaust!, single cat single 2.5? or twin cat single 2.5?.
    love the stato
    Haha, just the single mate - lighter is better
    Quote Originally Posted by greenfoam View Post
    I thought, when the white lines join together you are going too fast
    lol, that's when you know you've reached the point that the brakes aren't going to help anymore
    Morton drives at under 2000 rpm everywhere so he only needs a single and light weight for when hes taking corners in 5th gear at 1999 rpm
    That's exactly it, greenfoam The Statesman is turning into more of a hills/twisties car than a straight line dragracer. What with me never actually getting out to Calder Park. Next on my list of things to do will probably be some nice swaybars, and a strut brace.
    Quote Originally Posted by TVR-161 View Post
    Morton get the barge weighed. itd be interesting to see how light it is
    That would be VERY interesting I perhaps need to steal hakhawk's scales one day. It would be worth the drive down to see his BMW.
    The 1972 HQ Kingswood
  2. #827
    Dirbatua's Avatar
    Dirbatua is offline Say No to Chev Badges
    VX SS, VR Clubsport
    Apr 2003
    S/e Victoria
    cant wait to go for a run in this again, been yonks since ive been in it.
    so you wouldnt be interested in bringing it to the heathcote day?
  3. #828
    Morton's Avatar
    May 2006
    I'll be heading up to Hakhawk's joint on Thursday night to have to old girl weighed, and to see his BMW
    Let's say the standard weight is 1533kg according to my manual. Is that with or without fluids? I don't know...
    But let's take bets on what the old girl is gonna weigh I'm saying... between 1400-1450kg. I'm going to be conservative Who knows how far out the factory weight is!!
    But either way, we'll have an accurate reading on Thursday night ^_^
  4. #829
    Morton's Avatar
    May 2006
    Quote Originally Posted by Dirbatua View Post
    What's happening at Heathcote?
  5. #830
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    My guess 1475.3
    and 3 Dangerous non ABS VN's
  6. #831
    VP Executive R-spec
    Jan 2005
    I reckon 1500 will be about on the money, could even be more than that. I believe mine weighs about 1450 (at a guess) either that or it's making alot less power than it should be
  7. #832
    Black VN MANUAL
    Feb 2007
    Top of Vic
    mine was 1360, with 18s charger and 50kg in the boot of audio, so i would be 1290-1300, but fo the stato, hmm 1460kg just a stab
    ~ VN POWER ~ Click the scales
  8. #833
    Morton's Avatar
    May 2006
    I'm placing my bet of 1480. I'm not going to be as specific as 88greenvn. But I'm betting close to him
  9. #834
    Morton's Avatar
    May 2006
    We'll make this like "the price is right". Closest without going over
    nb: on Greenfoam's advice, weight will be taken with a full tank of fuel. I'll fill up on the way into Moe ^_^
  10. #835
    Black VN MANUAL
    Feb 2007
    Top of Vic
    i didnt have a full tank when i weight mine :P i'ma cheater, i wanted to say higher but didnt want to copy lol
  11. #836
    Morton's Avatar
    May 2006
    hahaha, well yours will be accurate with the audio in the boot then
  12. #837
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
  13. #838
    Morton's Avatar
    May 2006
    hahaha, this is going to be interesting ^_^
    In the meantime, I busted a driveshaft One of the CVs tore a boot, threw grease everywhere, and then proceeded to fill up with grit and sieze.
    Not such a bad job changing them - I'll get some pics up once my pic host stops failing
    The allen bolts were done up SOOOO tight!! I could physically see the allen key bending 15 degrees while I levered it against the trailing arm and turned the wheel to undo the bolts. Then the key would snap back instantly into position. Damn good keys
    I'll get around to changing the other driveshaft when I can. May aswell make them both fresh ones from a VS. The ride's a lot smoother now
  14. #839
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Lol, least you didnt tear it to shreds like i did. They are easy to change though
  15. #840
    Morton's Avatar
    May 2006
    lmao, yours was a bloody mess, mate I was lucky I got onto mine early ^_^
    Did yours tear up anything beyond the CV? I can't remember.
  16. #841
    Aug 2005
    Mt Martha, Vic
    Nah was just the CV, but that CV was a brand new one i put in about 6 months prior to that
  17. #842
    Morton's Avatar
    May 2006
    Well you need to stop cutting loops around the carpark down on Mornington Pier. We all know what you're like, Geoff. Don't try and deny it
    *hides*
  18. #843
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Morton View Post
    There's them Unbreako Allen key's again - survived a VQ drive shaft change - very good job
  19. #844
    Morton's Avatar
    May 2006
    Quote Originally Posted by 88GreenVN View Post
    Hahaha I was thinking of you as I was changing them ^_^ I nearly died when I first saw the key bend, but then as soon as the bolt was loose, the key straightened up. I was shocked!
    Those things are invulnerable
    I need to take the bolts back off one at a time tomorrow and loctite them. Loctite is my friend
  20. #845
    88GreenVN's Avatar
    Jun 2006
    I rate them as one the best quality tools I own - and almost the oldest... maybe something in that..
  21. #846
    Aug 2005
    Mt Martha, Vic
    Cant believe you used an allen key. Thats way too annoying, i got an 8mm inhex on 1/2" drive. Much better
    And no danny boy, i wasnt cutting hoops lol
  22. #847
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I haven't really had a good look through here yet Morton, but I hope to. You boys almost make me jealous I'm not in Victoria
    Also someone let me in on these allen keys.. I've seen them mentioned a couple of times and I'm in need of a decent set or 2
    WTB: mulberry VN interior parts
  23. #848
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by savage1987 View Post
    Good luck on finding a set made of good quality grade steel. Bunnings = fail
    They have UNBREAKO stamped into them. And as Morton said 15 deg bend and no snap ting ting ting accross the floor in 3 bits. My dad gave me my set when I was a lad - almost 30 years ago now. oooow that makes me sound old
  24. #849
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
  25. #850
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    verdict is in
    1407kg, with 25l under full fueltank.
    original weight is suspected 1563kg from multiple sources.
    Attached Thumbnails Attached Thumbnails Morton's white VQ Statesman-30042009020.jpg
  1. vq statesman with vs statesman front
    By Mazzone_Child in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2012, 02:39 PM
  2. Morton's blue VP Executive
    By Morton in forum VN - VP - VG - VQ
    Last Post: 06-08-2008, 07:41 PM
  3. VE GTS in WHITE!!
    By Torquen in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-12-2007, 10:13 PM
  4. which white?
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2007, 12:13 PM
  5. White 94 VR BT1
    By AirStrike in forum VR - VS
    Last Post: 13-04-2006, 11:39 AM
Tags for this Thread
