Results 1 to 10 of 10
Thread: Coil pack confusing-HELP
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Default Coil pack confusing-HELP
    Hey,
    Im not sure whats wrong with my car,I have 2 coil packs and both r in good working order.
    Yesterday it wouldn't start over so i thought i might swap the coils packs over and it started.I took it for a drive and it was working beautifully,then i took it home and left it.
    Well...this morning i went out there to start it up and no go
    the thing wouldn't start! So i swapped the coil packs over(back to the one i had on Yesterday-the one that it didn't want to start with and u wouldn't believe it IT STARTED!!!
    Any ideas on what it might b?
    Also the bolt that holds the wiring into the DFI module,is that an earth??
    ~ VN POWER ~ Click the scales
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Replace your DFI module.... Since its series one replace the DFI module and coil pack off a series2, you wont look back. We blew about 8 coil packs and 5 dfi modules, finally replaced with series 2, and been going strong for over a year On the plus side i got really quick at replacing coil packs lol.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    I have 2 S2 coil packs and the car doesnt start untill i change them over i dont know whats wrong with it, Wiring??
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Oops sorry i posted in the wrong section can some1 please move it to the other section
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Bz Kn33z View Post
    Wiring, DFI, earth?
    VP Executive R-spec
    Jan 2005
    You must have a dodgy connection on the dfi. Very common just clean the connections all around and have a look all over the dfi for any dodgys
    Black VN MANUAL
    Feb 2007
    Top of Vic
    I think i found the problem, the connection on the loom was was dodgy, the lil pins that go into the DFI where way to wide and not a tight fit, i had another loom so i relocated the coilpack behind the strut tower with another connection and more wiring, seems to be fine had no problem yet, look in my car thread at the pictures of the sc14 set-up and coilpack relocation.
    89 VN Exec, 94 VR SS
    Dec 2007
    I had coilpark problems for agggges it was screwed but technically still worked, soon as the engine would rattle a little the coils would lose spark or w/e and lights out, definaately get an S2 one not only do they look better and last longer, you dont need to replace a whole row when one of them screws up
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Problem is fixxed, and i have 2 S2 VR coil packs not a S1 that went ages ago
    VN WAGON
    Sep 2007
    any one with s1 coil packs should upgrade the dfi and put in s2 coil packs best thing to do saves you less problems later as u may only need to change 1 pac instead of the whole lot.as the s1 gets way to hot and sends it into haywore mode lol..
  1. Coil Pack
    By Willow01 in forum Electrical Wiring / Questions
    Last Post: 06-12-2008, 08:37 PM
  2. VS coil pack
    By mark_1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2007, 06:29 PM
  3. coil pack
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-01-2006, 03:16 PM
  4. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
  5. Coil pack
    By tonysoprano in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2004, 09:19 AM
