i just bought my white vp executive s2 v6 it was owned by a old granny it had 100,000ks on it and it didnt have a scratch on it there are a few things i have done to it i have put a pod filter on it i took the bell mouth out and have installed a $1200 poineer sound system there are a few things i am looking to get for it
they are:
lowered
v8 throttle body
2.5 inch exhaust system with headers (dont know wether to get full or cat back)
chip
induction kit
shift kit
vp calais interior
rear tailight (faded)
open mouth grill
if there is anyone that knows were or how i could get these parts please comment me
also i am not sure wether to get rims or not i have ripped the hubcaps of now there just black i dont think it would look to bad once it is lowered but i am pretty keen for interceptors i dont know if this is true but i heard that cops pick on you for having them
so if there are any different mods that would make it look good or add power please let me know
do vn open mouth grills fit to vps
cheers.
Yeah, get your pod filter and trow it down the street because its costing you power. Run a STD airbox with highflow or normal pannel filter and run a 80-100mm felxi tube into it leading to the front bar where it can suck cold air. Try to avoid crossing rivers with this though, but it wont suck water in unless you have a fully 100% airtight connection to your airbox, which it wonthave. Think of it this way, ever drank from a popper with a straw that had a hole in it? you get no juice do you...
VN Grills wont fit VP. The angle of the headlights is different.
Originally Posted by davway
thanks man how much do u think this would usaully cost
ohk were do u usaully find them do u rekon u pull it or just keep looking on forums n that
thanks man that would be great
Ahhhh, the first mod list of a n00by. Welcome aboard mate! First off, put that bellmouth back in, it does sweet f/a. I learnt this even after several people on here told me not to even take it out. All it does is lean out the 2 rear cylinders. Nothing else. The bellmouth evenly distributes air to your cylinders. The best thing to do is leave it in.
In answer to your question:
lowered - Give Pedders a call, get shocks front and rear with matched springs. Will cost you a little bit, but well worth it. Get Sports Ryder gear.
v8 throttle body - You will need to get an adaptor plate too, as they aren't a straight bolt up fit. Even better, get a bored out 70mm T/B. You can get them off Egay easily.
2.5 inch exhaust system with headers (dont know wether to get full or cat back) - I used a set of Pacemakers with a single 2.5" exhaust, stock cat, no rear resi with a straight through muffler. Sounds alright as far as a V6 goes. I'm about to buy a VS Senator though, V6's are lame. But each to their own.
chip - Send Greenfoam a PM, he tunes chips, and he does it very very well. He will squeeze a few KW's out of your V6 mate, trust me. Half of this forum will back what i said up. He is the master. I'll get him to tune my Senator chip FOR SURE.
induction kit - Go to a Holden spare parts division at a Holden dealership, ask for a cold air intake with box and adaptor to suit. Will cost you about $70 all up, then spend $100 and get yourself a K&N panel filter with a cleaning kit. Best inventment for your V6 and will last most of your cars life.
shift kit - Make sure you find a DECENT transmission place to fit a B&M or similar kit WITH A LARGER BOOST VALVE AND CORVETTE SERVO. Another VERY good investment to get your 6 rockin'.
vp calais interior - Best bet is Egay, wreckers rarely have them, and when they do, they will mostly charge you alot for them when they are clean.
rear tailight (faded) - By that do you mean tinted? Be careful, i was defected for them once. Plus they look gay. Get some of the red with the indicator and reverse light strip thats clear. They look clean, tidy and slick. Up to you though bud.
open mouth grill - Get a VP GTS grille. I was lucky and scored an original, genuine brand new plastic one via a Holden dealership, if you ring around enough, you may locate one. They are expensive though, but fibreglass is gay and plastic is better. If not, try Egay.
Hope this helped ya out mate. Good luck with your money pit!! They are expensive, but damn the car bug is a great one![]()
Good advice there, all except the go to pedders part.
Skip that and go straight to industrial springs on South/Port road. Assuming your in SA
Yeah either way. Or if you are real tight on cash, get some Monroe GT gas shocks (same **** as Pedders basically, made in the same factory) and some King Springs.
He did Geoff (Wagon_Wheel)'s VS Clubsport tune......
thanks for this mate it should help alote
Ohhh lol yeah i get what ya mean now. I have a mate who works at Pedders near my house, i request for him and him only to touch my car when it's there.
I have some bad stories about Pedders.
is the adaptor plate the thing that sits on top of the T/B
I'm pretty sure it is mate. But get your hands on a bored out and polished 70mm V6 throttle body off egay. Will do about the same as a V8 throttle body and you won't need to worry about the adaptor plate. Up to you though mate!
Get some pics of that VP up soon.![]()
so u have a vp gts grille on your car now so if u selling it would u sell the grille to me or u want that on your senator
