Results 1 to 24 of 24
Thread: Adams Series 1 VN V6 (Lotta Pics)
    89 VN V6 Berlina
    Dec 2008
    Default Adams Series 1 VN V6 (Lotta Pics)
    Model: 1989 Series 1 VN Berlina
    Colour:
    Mixture of Silver and primer :P
    Body kit: Nil
    Engine Type: Series 1 Buick V6 231ci
    Engine Mods: Nothing yet
    Power: Not enough
    Exhaust: Straight through Cat with 2.5" zorst
    Gearbox: Std Auto
    Diff: Std
    Brakes: Std
    Suspension: Std
    Wheels/Tyres: Stockies
    Paint:
    Silver
    Interior: Front VT seats and rears coming shortly
    Stereo: Nil
    Future Mods: Rebuild Motor with a nice cam and 10:1 comp, Shift kitted auto with High stall, NEAR FUTURE will be a spray job, lowering and wheels
    When i bought it:
    How it is now:
    The Motor that will be built for it:
    PLEASE KEEP ALL YOUR **** OUT OF MY THREAD
    89 VN V6 Berlina
    Dec 2008
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Seems like its coming along, from when you first got it, the new motor when its done should be good what type of cam will you put in her.
    ~ VN POWER ~ Click the scales
    89 VN V6 Berlina
    Dec 2008
    not sure yet, i was thinking a 992a or 1114a, i want something suitable for the high comp
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Well well well, lgnd3800 returns. Weren't you permanantly banned under the username "lgnd3800"????
    You won't need a high stall for a V6 with no big power, cam and compression MIGHT see you JUST keep up with a bog stock 5 litre. And straight through cat? You mean a straight through muffler? Unless you gutted your cat and ran straight pipe through it? In which case would sound like **** and is pretty bloody illegal. I hear your car has a nice yellow sticker on it currently as it's sitting in your driveway.....
    pugga's Avatar
    pugga is offline More Power!!!!
    05 HSV Maloo R8
    Jun 2005
    Baxter
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    At least with a slightly warmed over V6, he might just make it out of the way next time a bus comes at him
    Cursed CX8 is offline Banned
    VY Adventra
    Feb 2008
    Walking distance to FG meets
    hey! its lgnd3800! Didnt you get banned?
    I personally wouldnt both with the shift kit, it only holds the revs slightly higher. Id just get a corvette or billet servo for the 1-2 shift, and if your keen the 2-3, 3-4. Its not really needed on the 2-3 and above because the revs arnt that high. But the servo will make good use. 10:1 compression is easily achieved. run a shaved head - 40thou should do, and high comp flat top pistons. That will get you close, while the block is bare you might as well get it dipped to clean it all up. Replace everything that needs doing and anything that might need it soon. As for the cam, if your going to go so big that you need a high stall then your going to be spending big on a tune and getting the box built for power.
    My old VS box has bigger bands and clutches, bigger valve bodies etc, but standard stall limit, stage 2 shift kit and mild servo. that cost me about $2500 for the build. But would handle the power.
    While you have the heads off you might as well get the die grinder out and make them flow a little better, dont go too deep otherwise you risk cutting into the water jackets. And that will **** your engine.
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    Quote Originally Posted by pugga View Post
    V6 =
    VN =
    lgnd3800 =
    Bus:
    lol... but a mock up senator with a 6.....
    missing 2 cylinders... but good luck with it.
    dont worry, il start a ride thread soon.
    Nanos's Avatar
    Nanos is offline Not a Mod
    VXII LS1 Berlina Wagon
    Aug 2007
    Frankston
    not sure why you watse so much money on a V6 all your going to do is after spending all that money kepp up with a 5lt. If you ever come up against a 5lt that has tune and headers then your screwed.
    take my advice, sell the heap, buy a push bike (road will be safer for us all). the money saved you could get some driving lessons.
    Once you have done driving lessons you could then buy a real car and that would be something with a V8, and if you think you can handle it get a LS1. but from the history i have seen you might be better of with the push bike.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    I'd say he would be safer walking. But he might step in front of a bus LOL.
    89 VN V6 Berlina
    Dec 2008
    Listen Guys, we all make mistakes in life i made mine early, now would you all please leave me alone, im sure you all have mistakes in life that you would regret and like to forget, my accident is one of those things, i think ive suffered enough from it all after losing my pride and joy that i spent alot of money on, now just drop youve all had your fun, get over it and get along with life
    hsvpunk's Avatar
    vy ss II M6
    Jan 2007
    Mornington, Vic
    i wasnt making fun of u in the thread.... i was making fun of Pugga sayn abt the vn v6 bit... but he has a 6 banger in his "senator"
    89 VN V6 Berlina
    Dec 2008
    89 VN V6 Berlina
    Dec 2008
    Quote Originally Posted by Classifi3d Calais View Post
    Thanks for the advice on the stally, im not really to keen on doing headwork myself incase i stuff it up
  16. #16
    VY Adventra
    Feb 2008
    yer fair enough mate, problem is getting professionally ported and shaved heads is about $1000, getting them shaved is about $60 lol. If you can get a set of heads from the wreckers and take them out a little with a die grinder then its worth it, Make sure you only take small amounts at a time though. Also get a set of valve seat cutters. 3 Angle seats are good for a little extra flow and a couple of kw. Not alot, but every little bit helps and they are tools you will continue to use on other engines etc.
  17. #17
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Quote Originally Posted by hsvpunk View Post
    It was aimed at me Bwahahaha. Was it you or Colli that was paying out JC on the VSS forum?
  18. #18
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
  19. #19
    Aug 2004
  20. #20
    Nanos's Avatar
    Aug 2007
    Frankston
    V6 make a great family car for getting the kids to school and back. they are far from a performance car. Take my advice and dont waste your money on it.
    Just drive it till you get your full licence then the money you save you could buy something with a V8. I have been there and done that with cars over the years and i still wish i just drove my underpowered engines and waitied till i could have a v8. i would then have had plenty of meny for mods to the v8.
    You must remember you are starting with less than 100rwkw. No matter what you do you will have to spend very big dollars to acheive what a ls1 has with just bolt ons. Plus imagine if you do acheive good power how much of a pig it will be to drive and not to mention how much attention you will get from the law.
    I currently have 220rwkw with just bolt ons. drives easy does not draw attention. To acheive that kind of power out of your v6 your have to spend more than i paid for the wagon and then it will not be useable as a daily driver
  21. #21
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
  22. #22
    Aug 2004
    eh, v6s go allright turbod or supercharged,otherwise its not really worth playing with.
    Nothing beats smashing v8s with ur "great family car for getting the kids to school and back"
    Turbo v6s are smooth, good on fuel, make easy power, lots of torque, turn lots of heads and raise lots of questions like,
    What the ****?
    Why did that just dose?
    How did that seeming standard vn-vr just spark up the rears and go sideways 60km?
    although its not all that cheap....
  23. #23
    89 VN V6 Berlina
    Dec 2008
    Quote Originally Posted by Cobez View Post
    Bit hard when you don't have a job and have a defect on your car too
    how would you know if ive got a job or not ?
  24. #24
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Going by the last time we heard from you on SC you told everyone you didn't, if you had a defect on your car, i imagine it would have been cleared by now considering you love your car and would want to drive it a bit.....
  1. Replies: 14
    Last Post: 26-02-2008, 08:29 PM
  2. Some fresh HSV VE Maloo Pics (Interior and Tailgate pics)
    By 1991_Vn2nV in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-10-2007, 01:27 AM
  3. pics need of series 1 vn v6 cam
    By krawczuk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2006, 10:49 AM
  4. VT SS Series 1 pics needed....
    By AirStrike in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2005, 11:04 PM
