Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: VN 3.8 Turbo Wagon
    VN Wagz's Avatar
    VN Wagz is offline PshhhhHHT- **TuTuTuTu**
    VN Berlina V6 Wagon
    Sep 2008
    Dunlop (North Canberra)
    Default VN 3.8 Turbo Wagon
    Hey all, thought i'd show you some pics of my everyday driver... bought her a few years back as a bog stocker, with yucky 14" rims, tiny brakes and 4x4 ride height. Still, she came with cruise, power windows, factory LSD and was a one owner car, for $2500- a bargain!
    Mods since purchase are:
    Lowered all round, new springs and shocks and rear swaybar, strut brace.
    VT 297mm Front brakes, with matching VT booster.
    Turbo kit- T3/4 hybrid, intercooler, external 38mm wastegate, boost controller, rising rate adjsutable fuel reg... etc etc. Stock injectors and tune for the timing being, running higher base fuel pressure.
    Still rolling with the factory TH700 which is not liking the turbo- the torque its making is unreal, but the auto is slipping and slurring badly, so thats the next thing (after a proper tune). Hope you like
    Original breathing mods...
    VT Stoppers
    Turbo kit going on:
    Once on
    Stealth
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Mate that's very cool! I'm so happy that there are more and more boosted VN's around
    Love the black cooler too! - fantastic!
    now go get some bigger injectors and a proper tune and report back!
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    looks good. people wouldnt suspect it had a turbo under the bonnet.
    The Black Beauty
  4. Default
    why the hell is everyone's car turbo'd except mine?! this ride is AWESOME!
    how much has the turbo setup set you back?
    Quote Originally Posted by zai View Post
    I am not sutpid
    VN Wagz's Avatar
    VN Berlina V6 Wagon
    Sep 2008
    ahh, cheers for the comments. Yeah, i built it up to be a sleeper, its pwns cars right now without trying, but sounds like a stock VN V6 when off boost. On boost its not loud either, it just moves hardcore!
    Will be looking at 10psi once she's tuned, and north of 200rwkW, then we'll be looking at built internals and GNX alloy heads from the US, and a swap to a GT35/40R, and 13-15psi, for 240+rwkW ...
    this turbo kit owes me 4K on the car as now, but still needs a BOV, 36 or 42lb injectors and a Kalmaker tune. I've got a larger fuel pump (Walbro GSS341) and 2 Bar Map Sensor ready to go, but havent installed yet.. the kit was bougth off an eBay seller from some performance shop in Queensland (which has since gone bust?) and they only made 3 kits- their development one, mine and one which is on a VP ("vspt" on the Street Comms forum).
    Seeing how the manifolds and pipes in this kit is hugely better than a lot of others out there, im expecting this setup to be good for some awesome power once the big turbo goes on...
    The only thing i dont like about my kit (and most out there) is the loss of the Air Con, im so feeling it right now... *stinking hot*
    VN Wagz's Avatar
    VN Berlina V6 Wagon
    Sep 2008
    Forgot to mention, im going to try my hand at developing a lowmount twin turbo (or single) kit for the buick V6s later this year, similar to how the APS TT kit is setup for the 5.7L Gen 3s... lowmount black piping that hides from prying eyes, a water to air cooler hidden under the airbox location, feeding up internally through the stock air intake.
    Going to try making it look like a stock VN-VR engine but twin turbo and W2A cooled, and get it working for under 3k. With no extractors, crossover pipe etc, shouldn't be too hard, and the turbos will be located in a good spot to have them plumbed up to an exhaust (will also keep excess heat out, and can retain factory thermo and shroud).
    Going to try getting them really close to the sides of the gearbox, so that we can bolt them onto the box itself by way of some bracketry... a set of small GT28s should be good for fast spoolage and solid top end- they will eb the most expensive tho, as i have to buy ball bearing ones so that the oil flow can be unrestricted, as the oil retunrs will need to flow back uphill a bit to return to the sump...)
    Want it to be so good that a random roadside inspection turns up NOTHING when the bonnet is popped... only way to find it is on a hoist
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Nice wagon mate, its the last thing people expect is a v6 wagon to have a turbo straped to it, i know i get a few weird looks. Well done and good luck with the kit, check out my wagon i made all the manifolds and pipeing for it.
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
  8. Default
    something like this hey? APS Intercooled Twin Turbo Pontiac GTO/Holden Monaro - LS1 & LS2 Engines
    i'm in love with turbos, almost a definite to get mine done one day. i've heard that stock 304s can take 5-6psi no worries. i hope that's true. should be enough to get me started
    I am not sutpid
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    VN Wagz's Avatar
    VN Berlina V6 Wagon
    Sep 2008
    yeah, im not quite sure about how much a stock 304 can take, but i do know my brother's supercharged 304 (Yella Terra PD blower kit) runs 8psi happily... i think with it, the only limitation is the head clamping, they arent all that flash in stock form.
    VQ 5L - 12.6@108 stock bottom end & comp
    Sep 2006
    Most Intercooled Supercharger kits (ie vortech) run 10psi on a 304 without any issues, so long as the tuning is up to scratch.
    As i've said before, i really like this car cos I have a wagon also (VR) and i have grown to love it. So practical and reliable as shit. Plus yours has a bonus of boost. Win!
    Get it tuned! then 35/40 ala Boosted_Wag and 19psi FTW!
    Last edited by DeViLisanAnGeL; 09-02-2009 at 12:58 PM. Reason: apparently brain wasn't functioning
    VN Wagz's Avatar
    VN Berlina V6 Wagon
    Sep 2008
    ... or, im even thinking about going for a TT setup using two of these turbos- i have a spare one kicking around at home... you know, just in case
    May need a 3000 stall convertor to get them both spinning, but meh, who cares? Something to think about for the future.
    VN Wagz's Avatar
    VN Berlina V6 Wagon
    Sep 2008
    forgot to mention- heads are coming off, cos i popped a gasket whilst trying to tow a ski-boat... wouldve worked, but i think under long time at high load, i leaned her out (prolly drained the stock fuel pump i think..) and she started making bang pop noises...
    Pretty pictures up soon, showing a) nice chomped head gasket, and me smiling or b) cracked/fractured pistons and me doing a sad panda impression. Although, i do know that the head gasket is gone... for some reason i thought it would be okay. LOL, poor wagon...
    Once the motor is back together (this weekend i'd say, if no major damage), i'll install the walbro GSS341 in tank pump, just to give a bit more safety until it gets a proper tune. Also getting the stock V6 radiator end tanks put onto a VR V8 core, which is twice the thickness, and getting the block and radiator flushed out, i think the bottom of the motor is gunked up solid (pulled the drain plugs a while back and NOTHING came out, motor was filled with coolant and thermostat removed!!!).
    turbo assembly is pr1ck of a thing to remove and reassemble, but shouldnt take too long. Im gonan get the heads resurfaced and assembled again with stock gaskets, as they'll take as much boost as i can throw at them and will at least serve as a 'fuse' for my stock motor.
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    stock tune + boost will pop the headgaskets every single time mate!
    i learnt this one the hard way!
  15. #15
    ToxicVn's Avatar
    ToxicVn is offline Toxic_Vn_Wagon
    VN S1 Station Wagon
    Apr 2007
  16. #16
    VN Berlina Wagon
    Mar 2009
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Quote Originally Posted by PaRaDoX View Post
    I also have blown head gaskets on stock tune, just waiting on my new tune with bigger injectors to go in
    has it been dynoed? whats the estimated rwkw?
    ~ VN POWER ~ Click the scales
  18. #18
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
  19. #19
    VN Wagz's Avatar
    VN Berlina V6 Wagon
    Sep 2008
    Now running a Bosch BOV just before the Throttlebody, seems to be helping to keep the intake temps down (no more air compressing in the intake piping from pressure buildup at part throttle- it now bypasses), and have taken delivery of a set of 36lb super-6 injectors.
    All i need now is to get her tuned (Kalmaker most likely), but i think the auto will die really quickly if i even take her anywhere near an dyno- at half throttle it takes a few seconds to drop into third and the box just surges and churns before dropping into gear... not fun. And this is with only 5psi- we would be looking at 10psi when getting it tuned.
  20. #20
    1994 Toyota Supra JZA80 N/a
    Feb 2006
    Melbourne - Western Sub's
    Thats awesome. seeing more VN - VP turbo charged. Ultimate sleeper. Keep itup champ
    LOVE THE RICE BUT DONT HATE THE V8
  21. #21
    Fun_Bucket's Avatar
    Fun_Bucket is online now Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Hey mate, did ya notice a difference after fitting the front strut brace? Ive seen a few going pretty cheap, but i just dont know if it's worth the purchase??
  22. #22
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Nice wagon mate looks like it would fly, GL with head gasket.
    ========My Statesman 20's Mafless and 3.9's========
  23. #23
    VN WAGON
    Sep 2007
  24. #24
    VN Wagz's Avatar
    VN Berlina V6 Wagon
    Sep 2008
    new dump pipe gets fabricated up next monday at Fyshwick Exhaust Centre, sick of the current one hitting the strut tower and chassis rail. That means some coil pack relocation over the next few days, to up behind the passenger side strut tower. Only thing im not keen on is buying new leads, these ones are barely 5000ks old...
    Will get pics up once done.
  25. #25
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    nice wagon mate love the colour
    VN Calais With All The Factory Fruit I Need!
  1. VR Turbo V6 wagon - 11.74sec 1/4 mile
    By boostedwag in forum VR - VS
    Last Post: 30-11-2010, 02:09 PM
  2. Super Charger, Twin Turbo Or Single Turbo On My Vx Need Suggestions
    By GMHG3N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 11:38 PM
  3. VIC fs: modified vn wagon rear skirt, t28 turbo
    By hakhawk in forum Parts And Other Items For Sale
    Last Post: 08-11-2008, 06:28 PM
  4. my TWIN TURBO VK wagon, and GTS kitted VL
    By BIT_SUS in forum VB - VC - VH - VK
    Last Post: 27-12-2006, 05:23 PM
  5. vp wagon twin turbo
    By VPWAGZ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2006, 11:53 PM
