FOAMING VP STAGE 2
Parts to be installed during 2009
- Wade 325B1158B12 Camshaft
- Rollmaster red timing chain
- Speed Pro LT1 Springs
- Ported VR Heads 10:1 compression
- 27 thou Cometic head gaskets
- Cut banana manifold 10 inch runners
Expected power 210-220 rwkw, Hopefully with this combo will run 12's (it should, just)
I'll be doing this in several stages so the car is on the road as often as possible. First the valve springs will be installed on the original heads. Hoping to do this sometime this week.
Camshaft will be installed possibly the following week
Manifold will be completed as soon as possible (during this month I hope)
Then Manifold will be tested
Then the new heads will be machined along with the manifold and installed
And that's it, even taking into account slacker time it should be all ready to run a time with the re-opening of the drag strip in October/November
I plan on doing a full detailed picture thread of the entire cam/head/manfold work so I'll update this as it happens
Simulation data
Code:
Engine_RPM 800 1200 1600 2000 2400 2800 3200 3600 4000 4400 4800 5200 5600 6000 6400 6800 7200
Brk_Tq 220 249 254 260 275 283 297 329 349 354 352 345 329 306 272 235 199
Brake_HP 33.50 57.0 77.4 99.1 126 151 181 226 265 297 321 341 350 349 332 304 273
Exh_Pres 0.0 0.0 0.0 0.1 0.1 0.2 0.2 0.4 0.5 0.6 0.8 0.9 1.0 1.1 1.1 1.1 1.1
Int_Vac 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.1 0.1 0.1 0.2 0.2 0.2 0.2 0.2 0.2 0.3
Vol_Eff 62.7 71.4 72.9 72.9 76.9 79.7 83.7 92.3 98.4 101.3 102.7 103.1 100.7 97.8 93.4 88.4 85.0
Actual_CFM 50.7 78.9 103 128 162 196 236 292 346 392 433 472 496 516 526 529 538
Fuel_Flow 17.71 27.58 35.85 44.78 56.7 68.6 82.3 102 121 137 151 165 173 180 184 185 188
Nitrous 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Ntrs_Fuel 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
BMEP 109 124 126 129 136 141 147 163 173 176 174 171 163 152 135 116 98.9
A/F_Mxtr_Qlty 76.7 84.9 92.4 99.4 100.0 100.0 100.0 100.0 100.0 100.0 100.0 100.0 100.0 100.0 100.0 100.0 100.0
BSFC 0.529 0.484 0.463 0.452 0.451 0.454 0.455 0.452 0.456 0.461 0.471 0.483 0.495 0.517 0.553 0.608 0.688
Thermal_Eff 28.14 30.78 32.52 33.68 33.84 33.83 33.92 33.96 33.76 33.55 33.15 32.74 32.49 31.81 30.71 29.26 27.36
IMEP 121 137 142 146 155 161 169 187 198 203 203 202 195 186 171 154 139
Frctn_Tq 23.88 27.54 31.26 35.04 38.09 41.20 44.39 47.66 51.0 54.4 57.9 61.4 65.1 68.8 72.6 76.4 80.4
Frctn_HP 3.64 6.29 9.52 13.34 17.40 21.96 27.05 32.67 38.84 45.58 52.9 60.8 69.4 78.6 88.4 99.0 110
FMEP 11.85 13.66 15.51 17.38 18.89 20.44 22.02 23.64 25.30 26.99 28.71 30.48 32.28 34.12 36.00 37.91 39.87
Mech_Eff 90.2 90.1 89.0 88.1 87.8 87.3 87.0 87.4 87.2 86.7 85.9 84.9 83.5 81.6 79.0 75.4 71.3
Motoring_HP 3.68 6.44 10.44 15.15 20.23 25.69 31.58 38.17 46.77 57.0 69.8 84.7 98.3 114 132 148 164
Pumpng_Work -0.04 -0.15 -0.91 -1.80 -2.83 -3.73 -4.53 -5.50 -7.93 -11.39 -16.91 -23.85 -28.95 -35.74 -43.38 -48.82 -53.5
Residual_Exh 4.6 4.3 7.8 9.0 7.2 6.5 6.8 5.2 3.7 3.2 2.8 2.2 2.1 2.2 2.6 2.9 3.6
Shrt_Circuit 1.0 0.7 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.1 0.1 0.1 0.1 0.1 0.0
Exh_Temp 1143 1244 1302 1339 1369 1386 1396 1408 1418 1428 1433 1441 1437 1435 1413 1376 1321
Mx_Cyl_Pres 718 767 778 793 833 856 902 993 1053 1082 1095 1099 1067 1034 975 908 843
Mx_Cyl_Tmp 4646 4628 4518 4507 4542 4530 4506 4548 4594 4595 4595 4624 4601 4568 4490 4370 4144
In_Port_Tmp 155 152 152 150 142 136 131 124 117 115 111 109 106 103 98 98 96
Piston_Spd 403 605 806 1008 1210 1411 1613 1814 2016 2218 2419 2621 2822 3024 3226 3427 3629
Piston_Gs_@_TD 30 80 140 220 310 430 560 710 870 1060 1260 1470 1710 1960 2230 2520 2830
Coolant_HP 28.58 35.93 43.58 52.1 60.5 68.1 76.3 85.2 94.2 104 113 123 131 141 147 152 152
Blow_By 13.5 14.7 15.2 15.6 16.4 16.9 17.8 19.6 20.6 21.2 21.5 21.5 21.0 20.3 19.4 18.2 17.2
In_Tun_Pres 0.0 0.0 0.0 0.1 0.2 0.2 0.6 1.7 2.7 3.8 4.4 5.3 5.3 5.5 6.1 5.6 4.4
Avg_In_Vel 36 54 73 91 109 127 145 163 181 200 218 236 254 272 290 308 327
Avg_Ex_Vel 36 54 72 89 107 125 143 161 179 197 215 232 250 268 286 304 322
Mach_# 0.062 0.093 0.124 0.155 0.186 0.217 0.248 0.279 0.311 0.341 0.372 0.403 0.434 0.464 0.483 0.498 0.499
Act_In_FlowAre 96.4 96.4 96.4 96.4 96.4 96.4 96.4 96.4 96.4 96.5 96.5 96.6 96.7 96.9 99.2 102.3 108.1
Act_Ex_FlowAre 96.1 96.1 96.1 96.1 96.1 96.1 96.0 96.0 96.0 96.0 96.0 96.2 96.3 96.6 97.6 101.7 98.7
Valve_Toss None None None None None None None None None None None None None None Int In&Ex In&Ex
