Results 1 to 4 of 4
Thread: VR Starting Fault
    1994 VR Wagon and 1997 VS Calais International
    Jan 2007
    Default VR Starting Fault
    My Vr doesnt want to start
    Turn the key and nothing
    Press the remote button to lock the doors, then open the doors and it will start
    Whats going on
    Stop looking for the Potholes and sit back and Enjoy the Ride
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try moving the gear selector to N and pack to P whilst holding the key in the start position as it could be the inhibitor switch which stops the car starting in D or R. Keep your foot on the brake whilst you do this.
    Good Luck.
    VR Equipe II
    Mar 2008
    QLD
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    Hi,
    I had the similar issue, accessories working, but the engine not turning over until you take the key out and press the remote locking on then off. i thought it was an immobiliser issue.
    After a while I found it was simply that the two metal tabs that the key touches when the key is in the ignition weren't making contact with the key, pressed the key inwards when turning it around to start and hey presto! starts first-time/everytime!
    hope that helps
  1. A fault already??
    By KITTAU in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-05-2007, 03:45 PM
  2. srs fault
    By dagar187 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-03-2007, 04:10 PM
  3. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  4. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
  5. starting then dead fault
    By HSVGTSTOY in forum Electrical Wiring / Questions
    Last Post: 10-03-2005, 04:02 PM
