Results 1 to 6 of 6
Thread: Hot cabin air???
    VR SS
    May 2009
    Talking Hot cabin air???
    Not to sure what it is as only got car last week etc. But there is like 2 small tubes "copper??" that run up the inside of the drivers side floor hump running behind the radio that is pumpin out a hell of alot a heat. Is this the tubing for the heater? If so why would it constantly be so hot "to the point if touched would burn" Thanks for any advice.
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    If your car has climate control and the air conditioning is on then you should expect this pipe to be hot, even if the temperature is set quite low.
    If you haven't got climate control, then I expect that you problem is related to a vacuum leak or a faulty heater tap.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you look down near where the 2 brass tubes are you will see a cable and clip arrangement part of which moves when you turn the heater dial to cold....anyway, it's not uncommon for this to get kicked off and out of adjustment - this results in the heater tap being on at all times. Good Luck.
    VR SS
    May 2009
    Quote Originally Posted by hako View Post
    Ok checked the small clip , and all good is working properly , changes to cold and hot etc
    VR SS
    May 2009
    Quote Originally Posted by aceventura View Post
    Ok how would I test to see if have faulty heater tap and or a vacuum leak?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by valiant View Post
    Get someone to turn the dial from hot to cold while you watch the heater tap - the vacuum servo arm/lever should move....if not it means there is no vacuum to the tap. Another way is to pull the vacuum hose off the heater tap - it should be sucking strongly if on cold (or vice-versa). Both test with motor idling.
    Good Luck.
  1. Petrol smell in the cabin
    By jimmybobrowe in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-11-2008, 07:20 PM
  2. Cabin Filter
    By Dak666 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-07-2008, 03:41 PM
  3. Ute cabin sqaure feet?
    By aperfectcircle in forum Car Audio
    Last Post: 19-10-2007, 11:36 PM
  4. Cabin Struts
    By VX_Wannabe in forum Parts And Other Items For Sale
    Last Post: 17-09-2007, 02:53 PM
  5. Cabin
    By The1985divo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-01-2004, 07:08 PM
