Results 1 to 6 of 6
Thread: t5 gearbox problems
    blaze's Avatar
    blaze is offline ridin dirty
    SILVER BULLET
    Jul 2006
    bunbury
    Default t5 gearbox problems
    hey having sum whinning noises coming from my car i think its coming from the gearbox, u can only hear it when u got ur toe on the accelarator just cruizin. im hopeing like hell it aint a bearing because it cost me big $$$ last time to get it fixed in my old T5, im also thinkin/opeing it could just be low on oil.
    so my question is where is the fill up hole on the gearbox? i had a quick look last night b4 it got too dark and i seen a allen key bolt on the bottom side of the gearbox is this the plug to top it up?? n what side is it on??
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    That will be the drain plug mate. The fill plug is a bit higher up on the drivers side
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Drivers side just above half way up. It's a allen key type bolt and looks similar to the drain plug on the bottom.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    car
    Jul 2006
    greensy, melb
    yeah the fill plug is right above the drain plug and when you drain it out put the bottom plug back in and run a hose with a funnel from the engine bay to the top hole on the box to fill it.
    i always fill it till the oil starts coming out the top hole in the box so you know its enough and another thing try using a tube of lubrizol with auto fluid as it works great with these box's and i wouldnt go back to anything else
    "A life lived in fear is a life half lived"
    blaze's Avatar
    SILVER BULLET
    Jul 2006
    bunbury
    yeah i filled it up this morning and its still making the whine!! grrrrr!!! ****!!!! im beginning to think it is a bearing now, last time getting a bearing replaced cost me $1500 ( i got stooged, fkn wankers!). im going to have to get it fixed none the less just take it elsewhere this time..
    few questions
    do u rekon its worth spending the money on the t5,or spending the money gettin a supra box or something like that?
    what gearbox is ideal? what can take a bit of abuse? ive seen nothing but trouble from t5's, this is my second t5 with issues, and my mate blew his reverse in his
    would a supra box bolt straight up or do u have to get a diffrent tail shaft or anything else?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    probably lay shaft bearings its not that hard to build a manual yourself if you have some mechanical nouse.no gearbox will like WOT too much really they all go in the end unless you go for a T56 or something silly.ive run supras on my old VK 308 was fine used to tow transporter decks with it and stuff just dont drive hard or tow in 5th or youll spin the cog off the shaft making it a 4 speed.but again they dont like to much full throttle action.
  1. gearbox problems
    By maxpower QLD in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-06-2008, 01:34 PM
  2. Gearbox Problems
    By rus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2006, 02:41 PM
  3. VL 5sp gearbox problems
    By mekam in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-06-2006, 04:16 PM
  4. VT gearbox problems
    By VT_Mania in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2005, 09:26 PM
  5. Gearbox problems
    By hsvd_g in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2005, 03:17 PM
