Results 1 to 2 of 2
Thread: Vr V6 Starting Issue
    Vr Executive 3.8
    Dec 2008
    Default Vr V6 Starting Issue
    Hey guys I've got a 93 Vr V6 Auto and yesterday she wouldn't start.
    It had enough battery power and cranked over without an issue and the fuel pump was running without a problem but it would just not start.
    I disconnected the battery and reconnected it and tightened all the connection which didn't make a difference.
    I pulled the relays for the starter EFI and Fuel pump then replaced them then the car started but I don't think this is what fixed it.
    The car runs fine again now just wondering if anyone knows what the problem was so I can fix it before I get stuck somewhere?
    At a guess I'm thinking something to do with spark? Ignition Modules?
    Thanks guys
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd check codes first:Checking error codes VR/VS (Revised)
    then I'd make sure the key battery is OK and it's making contact with the key reader around the ignition keyhole. If the car battery is more than 2 years old I'd replace it anyway....cheap insurance...plus Commodores need a good battery for the electronics and if the problem happens again you will have plenty of reserve battery power.
    Good Luck.
  1. Starting Issue
    By ecotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 03:52 PM
  2. Starting Issue
    By Anthraxnz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-07-2008, 07:34 PM
  3. Odd starting issue
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2007, 02:21 PM
  4. Not Starting/Stalling Issue
    By Emackulation in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 03:29 PM
  5. Starting Issue
    By Glover0 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2006, 10:29 AM
