Results 1 to 13 of 13
Thread: VR engine loom and manual harness into VS
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default VR engine loom and manual harness into VS
    I've got a manual conversion from a VR to go into my VS, including manual computer, BCM and loom. The bloke who sold it to me recommended I use the manual harness, and get an auto electrician to wire it into the existing auto loom. In otherwords, use all the existing wiring/computer/BCM but just replacing the gearbox harness with the manual one.
    I'm of two minds what to do, is it even possible to replace the entire loom? Since the VR was a different engine there would be different connectors, correct?
    Just after some input on my best course of action. What problems am i likely to encounter?
    Cheers.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i think you need the key coded to the BCM to use the VR bcm so that would be out to start with im sure.
    Dec 2008
    I have the VR key that came with the BCM, but i doubt it would fit my ignition due to the cut of the key itself.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah.im not sure on the difference in bcm's between vr and vs but ide say it wont be pkug and play some how.you could rewire to the VR manual ecu and ditch the MAF sensor and the CAM sensor and run MAP would be a fair bit of wiring to do though.would need a different coolant sensor and an IAT sensor and would need to drill the manifold to fit it.
    Dec 2008
    Lol, yeah i think i'll just use the harness. Does this mean use the harness with the manual or auto computer?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    someone i know has done it with the auto ecu he just fed the new speed sensor feed into the correct terminals on the auto ecu and turned off the auto flags and has no issues.its easy to feed a few wires to the ecu
    Dec 2008
    Ok. Might have to go that route. Did your mate use the harness at all or did he just make up his own sensor wiring?
    Thanks mate.
    Gus The Snail's Avatar
    Gus The Snail is offline Born to be dizlegzic
    VS ute S2 1996
    Aug 2007
    ipswich - on the right side of the tracks
    Quote Originally Posted by delcowizzid View Post
    More info please.. and can anyone help with a how-to wiring diagram to get speedo and revers lights etc working on an auto converted to manual?
    Its not what you know or who you know , its how well you can fake it
    в∞ѕтεכ √&
    Jul 2008
    NZ
    Rob's Creative Calibrations - Wiring Diagrams feed the speedo into the manual VSS pin soarch power from the auto loom by the box for the vss too earth it to the box. maldotcom2 might have good pics for you
    VR Caprice
    Dec 2005
    You shouldnt need the BCM. The BCM will just plug in anyway the only prob you might find is if you electric windows you might have to bypass the bcm for them as they will not work properly.
    You will have to modify the 2 large plugs on the engine harness that plug in near the battery, its pretty easy its just the colour coding and the plugs are different.
    Dec 2008
    Got it all wired up. Didn't use the manual harness at all, just cut off the VSS and wired it separately. Gus, when you removed the auto shifter plate there would have been a plug with 4 wires, 2 the same colour and one pink and one green. The two the same colour are your park neutral sensor so just short them together. The pink and green are the reverse lights, they need to be connected to the pins on the left side of the gearbox, doesn't matter what order they go in.
    VS ute S2 1996
    Aug 2007
    Cheers for that , i'll get it done on weekend , but....What about speedo???
    Dec 2008
    Speedo is operated by the vehicle speed sensor on the right of the gearbox. It has 3 wires, positive, negative and signal which goes to pin D2 on your ECU.
  1. [WA] WTB VR/VS V8 cruise control loom/harness
    By undar8ed1 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-01-2009, 12:50 AM
  2. VT Manual engine wiring harness & com
    By kaoscommodore in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2008, 09:29 AM
  3. F/s Vn manual ecu and engine bay loom,
    By Haydz in forum Parts And Other Items For Sale
    Last Post: 20-07-2008, 11:07 AM
  4. W2B: Needed : VN Lvl3 Connector 4 Harness/Loom
    By StealthX in forum Swap / Wanted to Buy / Trade
    Last Post: 20-04-2006, 07:48 PM
  5. WTB: VT - VY Manual Engine Harness
    By OZ38 in forum Swap / Wanted to Buy / Trade
    Last Post: 15-04-2006, 09:24 PM
