Results 1 to 8 of 8
Thread: VX injectors on a VS?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default VX injectors on a VS?
    hey all.
    just a question about injectors. i have a set from a vx ecotec and was wondering if they would fit a VS commodore v6? they are skinny blue injectors.
    if so what would be the benifits of installing them on the vs? if any?
    cheers
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Many companies now try to sell the stock VT-VY (Bosch 777) injectors for all makes VN-VY. The flow rates are marginally different to the standard VS injectors, and they claim they you do not have to get a new tune to run them, providing you change all 6.
    I am not sure about the advantages, but I am pretty sure that the fuel pressure of a VS is different to a VX, which means your flow rate may be a little less than the stock injectors, hence less power - but I may be wrong. I have been heard that the VT-VY style injectors atomise fuel more efficiently.
    In any case, to sum up - They will work, but I think there may be small advantages and disadvantages. I would stick to stock injectors, but that's me.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    aceventura is on the money, flow rate is smaller (not my much 1cc from memory), but better atomisation. if you drop in the VX injectors drop in the VX fuel pressure regulator too, that will ensure the correct fuel pressure is maintained.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    ah ok lol well i have the regulator as well (the whole plenum)
    so basically if i change the regulator if should be ok?
    i have a greenfoam tune to so yeh (if that makes any difference lol)
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i didnt think foam did tunes for the ecotec, but yea swap the reg too and you should be fine. Actually swap the whole rail, that way worst case, if you have any problems u can just swap back the whole rail.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yup....foamy does do tunes for the ecotec/VS. works goooooood too lol
    ok ill change the whole rail over
    cheers
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
    Out of interest - I have noticed that the VT-VY fuel pumps are much more expensive than a VN-VS fuel pump, and I assume it is because they are heavier duty pumps. Are these pumps required to sustain the higher fuel pressure required by the VT-VY over the long term?
    I ask because I am interested whether the VS pump will fail prematurely due to the increased fuel pressure.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i dont believe they're a heavy duty, possibly could pump out more pressure. i believe they are the same part number.
    i havent had a problem with my fuel pump since i've had the vt engine, from memory its only the fuel pressure regulator that holds the pressure in the rail.
  1. injectors
    By King_berald in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-02-2009, 07:58 PM
  2. EFi injectors
    By Pub247 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-05-2007, 08:38 PM
  3. VR injectors
    By gonz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2006, 10:22 AM
  4. Injectors?
    By Torniquet in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-07-2006, 11:13 AM
  5. Injectors..
    By Lord-Data in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2006, 10:27 AM
