Results 1 to 7 of 7
Thread: level 3 dash
    Rumbl's Avatar
    Rumbl is offline = ShAkE AnD bAkE =
    VR V6 berlina-VS ss
    Jan 2005
    campbelltown nsw
    Default level 3 dash
    hey i got a VR and it has a level 3 dash but i think my petrol gauge is stuffed could i use a level 2 dash to check if its the gauge or are the connectors different?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by Rumbl View Post
    It will be the regulator inside the cluster that will have cracked solder joints.
    http://forums.justcommodores.com.au/...id-bit-fix.jpg
    and 3 Dangerous non ABS VN's
    Rumbl's Avatar
    VR V6 berlina-VS ss
    Jan 2005
    campbelltown nsw
    and where abouts is this located behind the fuel gauge or the bottom section?
    88GreenVN's Avatar
    Jun 2006
    Take the tacho and speedo out and you will be looking right at it.
    Rumbl's Avatar
    VR V6 berlina-VS ss
    Jan 2005
    campbelltown nsw
    88GreenVN's Avatar
    Jun 2006
    yeh i just found it but the bits you say need soldering looks fine to me
    Hmm - look over all the solder joints - use a pin to slide over the solder - feeling for a crack. Some times it can be the connector where the ribbon goes in. This can be cracked also.
    The gauges are almost never the problem - is the DTE working in the cluster - if zero chack the fuel sender connection.
    88GreenVN's Avatar
    Jun 2006
    If you plug the L2 dash in and the fuel gauge works - it will be the cluster. Sorry missed this bit about the L2 cluster fit. Yes it has the same wire config for L2 & L3 gauges.
  1. VR level 2 dash into VP level 1???
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2008, 02:28 PM
  2. level 2 tacho into level 3 dash
    By andynogo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2008, 05:34 PM
  3. How do I fit a Level 3 Dash into VP Level 2?
    By nsladden in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2007, 08:28 AM
  4. Level 1 dash cluster to level 3
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2006, 06:28 PM
  5. vs level 3 dash
    By danny1987 in forum Swap / Wanted to Buy / Trade
    Last Post: 26-01-2006, 09:06 PM
