Results 1 to 22 of 22
Thread: Does this sound like an okay deal?
    1994 VR Exec, 5.0L BT1
    Jan 2005
    Default Does this sound like an okay deal?
    VS V6 acclaim. 220,000km's, power windows, power steer, cruise control, abs, dual airbags, factory fit duel fuel. No rust anywhere. It's got all the factory books, including service history upto the warranty 5yr service. Comes with RWC and 12mths rego. The guy is asking $6,000 for it, we got him to $5k but tryin to get lower then that.
    Picked up on a few things lookin it over and on the test drive. Rocker gaskets leaking, muffler has a hole, rear window regs rooted, bootlid was full of water and steering rack was making a rubbing noise. Also when I punched it on the test drive in D with economy button on, it didn't change untill 6k/rpm. He's gnna get all that fixed and the transmission looked at and we'll go back for another look on Friday.
    Interior is near immaculate, even the passenger airbag cover isn't warped like most we've seen. And Dad bought his last car from this dealership, and it lasted 4yrs untill some bloke wrote it off, so I trust the dealer (within reason )
    Just looking for opinions from you guys, I'm sure you've all bought a few commies in ur time. I've looked at everything I know, maybe you'll know of something else to be checking.
    Srry to make another thread, but just trying to make sure we get a good car as it's going to be my dad's last car (unless it also gets written off ).
    Thanks, John.
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Boot full of water and steering noise are typical problems with easy fixes, so don't let that put you off. Just use it as a bargaining chip. Paint looks nice too.
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    i sold my mums car, exactly the same as you described bah the problems with 180k on it for $5000 with rwc.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    From an old blokes perspective the colour would put me off as it's not noticeable (camouflage) and being dark it will get awful hot when parked in the sun. At those Ks the trans will soon fail if it hasn't already plus CAS and HB. Power steering could be simple fix but if rack and pump need replacing it will cost upwards of $600. Boot full of water is probably the seals around the rearmost side windows gone....a cheap fix but a bugger of a job pulling them out and expensive to get it done professionally.
    5 years of warranty record still leaves 9 years unaccounted for!
    On the positive side it looks like an old bloke has owned it and it has 12 mths rego....price is normal for a dealer and it should come with a warranty.
    I'd get the trans checked independantly, also the steering as both can be doctored with a can of "quick fix" - the boot they will probably drain and clean and leave it at that.
    If it was to be my last car I'd go for lower Ks which would probably end up costing a few thousand more but it could be worth it....and there are plenty out there to choose from.
    In the end it's your old man's decision - good on you for trying to get the best for him.
    Jan 2005
    Thanks for the input.
    We looked around for a car with lower k's but as you said, they shoot up in price and the budget is $5,000. The avge seemed to be between 190 and 290,000. He doesn't do a lot of long trips, mainly home to the shops and back.
    I'll see about getting an independant to check the trans and steering, the dealer did offer to allow the mech of our chosing to do the roady and he'd foot the cost. But he said he'll get all them things fixed now, so I dunno if the offer still stands.
    Anymore info is helpful too, thanks everyone
    vr statesman 5.0
    Jan 2009
    hey man thats a rip off comparred to my mates supercharged vs that hes selling.he wants no lower than 7,500 for it,its white,auto,yella terra charger,roller rockers,cam,lifters etc,quick car and its immaculate john.it comes with reg roadworthy,and big sterio.lowered on ceptors,and just over 200,000 on the clock.i gotta put a thread up for him when i have more info on the motor specs.ive driven it a few times and its great to drive and quick.
    Fun_Bucket's Avatar
    Fun_Bucket is offline Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Did you say the Passenger airbag cover isn't warped, looks like it's warped big time on the top left, could just be the picture though...I reckon even for $5,000, with all that fixed, it's still a bit pricey, but hey, if your gonna buy from a dealership, then i'm sure your already aware of that.
    190,000, is getting towards the high mark, i currently have a VP, which has around 185,000 on it, although i purchased it with the intent to put a 5L manual into it, so i ignored the high kms, in favour of it's body and interior. And although it hasnt let me down once, it the 4 months now that i've had it, i wouldnt have bought it with that many km's, if i planned on keeping it for a long time.
    My advice is to look around privately, and although you won't be buying with a car with a warranty, narrow your search down enough, and have each car properly inspected, and then that way you will still be buying a used car with confidence..
    Acclaimed VS is offline cruising
    VS Acclaim
    May 2009
    I just bought my VS acclaim 2 weeks ago 3,300 private sale with 106,000 on the clock aprt from a warpd passenger airbag, a non-working fuel and temp gauge and a ****ed speed alert all of which arent big issues its great, I would reccomend looking at private sales as you can score a much beter deal and you can use the savings you keep as backup if and when something goes wrong. But yeh for those k's that price is a bit high i rekon. Car looks strait as though
    Jan 2005
    I know it's a bit high on the k's. I bought my VR at 220 2yrs ago, it's just turned over 260,000 and apart from the tranny being a bit rough it hasn't let me down yet but I use it everyday for work. The lowest k's I found was 150*** and full of rust. The nxt lowest was 180 and they just went up from there. Dad will be using this to go shops n back, that's about it, so the k's arent a huge deal, but still being mindful of them.
    With regards to the cover, it does look a bit lifted in the top corner. I have to say I didn't notice that when we looked at the car (I was focused more on the bodywork and motor) But compared to the others we looked at, nearly every1 had the entire outside edge lifted and peeled over. And it's a common problem so I've been told.
    Dad likes this car and I know it's costing more coz it's a dealer, but as I said he got his last car from this guy with no problems. He likes the passenger airbag and fact it's factory duel fuel. Also there's about $1k in the 12mth reg and rwc, which most of the private sales lacked.
    But yeah thanks for the advice, it's all helpful, getting lots of different viewpoints/opinions. This car isn't locked in yet, we are still gnna be looking around.
    And luke, he's over that stage in his life. Just needs something economical and safe. And not a fkn hatch
    WogBoyz's Avatar
    WogBoyz is online now Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    In the last pic what is the big circle thing in the intake piping just before the throttle body?
    sorry to barge in just never seen it before im a bit curious
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    There's low Km's bargains out there, just gotta be patient and keep looking. before i bought my current car,I missed out on an XE, one owner, factory manual with LSD, in white, less than 100, 000 on it, and just absolutely immaculate. I rang the guy the day the add was posted, but it was already gone...he was asking i think $1500 for it, apparently some guy showed up not long after putting the add up....Fark i would have turned that thing into a weapon!!!!
    Jan 2005
    Not 100%, but my guess was it is something to do with the factory dual fuel.
    VR Executive Wagon Manual
    Apr 2009
    Check with the Department of fair Trading, if the cars is more than "10 years" old or has more than "160,000 Kms" there is NO warranty! So make sure that all the things are fix before you part with the money.
    VL EXEC
    Aug 2008
    perth wa
    Quote Originally Posted by WogBoyz View Post
    turbo ^^ an intake turbo thats right ^^
    I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
    vp ss 3 months to go
  15. #15
    VR Commodore
    Apr 2009
    I think it's a gas mixer.
    I wouldn't pay that. I'd look at a VT with lower K's for that.
  16. #16
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    your getting raped. Dont pay that price
    no longer a hoon by association - the commodore is gone
  17. #17
    Jan 2005
    Could you guys maybe gimme the details for a VS with less kays, good paint, no rust, preferably with dual fuel, clean interior RWC and 12mth reg fro less then $5k in the Victoria eastern and/or metro area. Or at least an idea of where to look? Instead of just telling me I'm getting ripped off, because that's not helping.
    Basically where I've looked is the usual used car websites, ie. carsales, carpoint, drive, and the trading post. Been to a couple yards. And this is the best we've found.
    I'm not trying to be rude or nethin, but I can't find any of these low k bargains anywhere. And would really appreciate any info on something better alot more then just telling me I'm getting ripped off or paying too much.
    Thanks.
  18. #18
    VR Commodore
    Apr 2009
    Yeah avoid the car yards. Go private and save 2 grand. Even pay 100 bucks to a mechanic to come out and look it over. Small investment on the liability lol.
  19. #19
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by spd_dmn View Post
    Thanks.
    Go with your feelings spd_dmn ....if you feel good about the car then it's the car for your dad. There will always be someone who knows of a better deal, bought cheaper etc etc but apples ain't always apples.
    I usually look at 2 or 3 cars ...sometimes it's the first one - if it feels right I'll go for it.
    You've done very thorough research and arrived at what you reckon is the best car so you've got my vote.
  20. #20
    VS
    Dec 2008
  21. #21
    Jan 2005
    That pic is a bit deceptive, it's actually more a dark purple colour. They call it 'charcoal'.
  22. #22
    Jan 2005
    Well, I got my mechanic to check it out. It was a complete dud! The engine mounts were worn down to nothing, the rear main seal was leaking, the power steering was pissing out fluid. The radiator was leaking, the transmission was on the way out etc. etc. I'd picked up on the oil leak (thought it was the rockers though), the dealer downplayed the steering and auto problems when we went back on Friday after he was meant to have fixed them, which is why I got me mechanic to give her the once over before making the final decision. Good thing we did!
    Found a '93 toyota camry wagon with 160,***kms on it. 4cyl so will be good on fuel, with toyota reliability. Bloke said it was in good condition, so goin to check it out on Saturday
  1. sound system help, sound changes in middle of song!
    By Summer-Sickness in forum Car Audio
    Last Post: 13-04-2009, 02:54 PM
  2. Sound System high pitch sound
    By liquidforce_134 in forum Car Audio
    Last Post: 16-07-2008, 10:31 PM
  3. Whats the deal?
    By Z()LTAN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2006, 11:18 PM
  4. just bought sound system, will it sound good
    By pier_one in forum Car Audio
    Last Post: 02-10-2005, 01:27 PM
